97 Explorer Clunking Noise
Old Apr 26, 2004 | 12:59 PM
cherring's Avatar
cherring
My 97 Explorer with 123,000 miles has developed a thumping/clunking sound from the front suspension. No prior maintenance on suspension. Can anyone give me some ideas on parts likely to need replacement?
Old Apr 26, 2004 | 03:11 PM
marragtop's Avatar
marragtop
Sounds like it could be the radius arm bushings. Farily common when you get over 100K on them. Do a search on this forum for 'radius arm bushings'.
Mike
Old Apr 27, 2004 | 07:30 AM
mason's Avatar
mason
I don't believe '97s have radius arm bushings. Ford stop using them in the 1995 models. I would check out the ball joints.
Mason
Old Apr 27, 2004 | 04:53 PM
Bashman's Avatar
Bashman
As mason stated, only first gen X's had radius arms (91-94). Besides the ball joints, it could also be shocks.
Old Apr 27, 2004 | 06:00 PM
98xlt's Avatar
98xlt
Both my Dad and I had 98xlts that developed a clunk in the front end. It turned out in both cases to be the inner tie rods where they join the rack and pinion. If this is the case, hopefully it is just the tie rod end and not the rack itself. Also, if you do end up replacing the inner tie rods, I recommend going ahead and replace the outer tie rods with new ball joints that have zerc fittings instead of the lame sealed ones at the same time. I believe there is a TSB on this problem for your year if not 96.
papabills54
Aug 21, 2015 12:27 PM
hedhntr
1983 - 2012 Ranger & B-Series
15
Jun 5, 2015 01:30 AM
Primerranger
Mar 12, 2015 06:11 PM
Born Blue Bob
Dec 20, 2013 01:00 AM
SaleenX
Jun 15, 2008 07:42 PM
