Auto to manual hub tutorial
Old Apr 26, 2004 | 11:30 AM
seagull369's Avatar
seagull369
Does anyone know where i might find a tutorial (w/ pics) that could prep me for replacing my auto hubs with manual ones? Links to a site that might have some would be great. I have a Haynes manual but have found supplements often help compliment the areas in where the book lacks.
Also, does anyone know what type of grease should be used when putting in the replacements? Thanks
Old Apr 26, 2004 | 11:36 AM
Rockledge's Avatar
Rockledge
What year is your Ranger? (You should add it too your sig).
Old Apr 26, 2004 | 02:23 PM
seagull369's Avatar
seagull369
WHoops,,,sorry . It's a 94 Ranger aka B-4000.
Old Apr 26, 2004 | 02:34 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I replaced the auto hubs on my 94 Ranger with Warns; I seem to think they had some instructions included. However, if you know how to adjust or pack a wheel bearing, you can accomplish the hub swap. The existing Ford components for adjusting the wheel bearing go bye-bye and are replaced with a couple of rings made by Spicer. They work like two jamb nuts; if you can get your hands on a spanner wrench, tightening these will be much easier. As for the grease, just go to your local auto parts store and look on the can, it will tell you what vehicles it's recommended for. FWIW, there is a Ford spec on the grease (taken from my owners manual), it is ESA-M1C198-A.
Old Apr 26, 2004 | 03:36 PM
CowboyBilly9Mile
Usually I just look on the can for the recommended applications and make sure it meets or exceeds the manufactures recommended specs. I've been using Valvoline part #632; the container is about the same size as a container of cottage cheese. I'd also suggest avoiding non-brand names, but that's a personal preference.
zukinut
May 28, 2012 10:35 PM
jvwhittaker
Aug 13, 2010 09:20 AM
dwilliamsceg
Mar 9, 2008 08:46 PM
jmonintwo
Jun 24, 2007 10:32 AM
Mykro
Sep 30, 2003 10:51 PM
