DIY first time paint job
Make sure that you trust your supply people fully and that they know what they're talking about. Then you can decide on the brand of paint that you want. A gallon of base should be enough to do the exterior of the truck but if you're doing the inside of the box and the door jambs and fenders....etc. you might want another half gallon. It sounds like you're gonna use a single stage paint and then clear it right? If that's the case then you're gonna want to let the color coat dry for a couple days before clearing. You will want to get the same amount of clear as color or to be safe maybe a little more. As far as flash times and recoat times, all paints are different, get a Tech Sheet from your supplier they should have a binder full of them to photocopy. If you're gonna sand and polish this thing it would be a good idea to put on 3 full coats (you can also do 4, just remember to make sure you have enough clear) this way you'll have enough product that you won't break through when sanding.
Good luck and take your time.
Chris
Alberta
Is the metallic going to mottle? Yes Can you sand out dirt? Not metallic
Can you match it for a repair? Only with a 3 stage blend,that looks like a color fade attempt. Can you pick that knat out that did the double winged backstroke down in the virgin wet paint on the hood? Nope let it dry sand repaint. Can I tape it off for the center color of my two tone paint job? Better make sure you wait longer than the can says or you'll cover that truck with tape tracks. Does it sag, run, tear, and drip easy? Only everywhere that gravity is in effect.
What does two stage paint help to remedy?
Metallics lay evenly with a properly applied drop coat.
Can tack off overspray,or bugs, lint, mystery particles whatever is on it between color coats.
The products are forgiving. Meaning you are going to make a couple of mistakes in the spraying, but the product is so forgiving that like even if you run the paint it nearly fixes itself as it dries.
Good for re-matching colors- some yellowing of the C.C. can happen after the 5 year mark.
Buff old clearcoat,and get good shine, solid or metallic.
30 minutes dry time to tape free for striping, two tones ect.
The clear coats are super high performance, they hold up 10 years now in UV tests.
Don't fear this stuff. Take the big leap into the Twenty-First century you'll be glad you did.
more pics on this thread
http://www.naxja.org/forum/showthread.php?t=37597
Looks like the silver hides the dents well. Did you have any problems with the HF gun? I saw the exact HVLP on sale yesterday and have been wanting a gravity feed....BTW...That's quite a roll cage/rack. Has it shown any sheet metal stress at the points it goes through the roof? (I assume it goes through.) Bet that is one stout rack!
