roller ready block?
Old Apr 22, 2004 | 09:17 PM
badassfordpu's Avatar
badassfordpu
roller ready block?
I have an 86 f 150 5.0 ND WAS LOOKING FORWARD TO CONVERTING TO A ROLLER CAM BUT IDONT KNOW IF IT IS ROLLER READY. HOW CAN I TELL FOR SURE WITH OUT REMOVING INTAKE? CASTING #S BEGIN E6...
Old Apr 23, 2004 | 08:07 AM
jwtaylor's Avatar
jwtaylor
The easiest way on a 5.0 I believe is take a look at your firing order, what is it? Most, if not all, roller or h.o. 5.0 motors I believe came with roller cams as the 5.8 roller blocks in some cases didn't.
If your firing order is 13726548 then its probably a roller or someone stuck a 351w flat tappet cam in there.
Best way, take the intake off and look at the oil valley, you will see two holes that accept small bolts to hold the spider retainer down.
I don't think the truck 5.0's were roller or roller compatible in 86 if the motor is original.
Sorry I don't have a concrete answer, maybe someone will, good luck
1996pwrstrk
Oct 27, 2011 12:13 PM
my93
Engine Swaps
Jan 19, 2011 08:26 AM
Jrock909
Feb 3, 2007 10:57 AM
Show-N-Go LX
32
Nov 29, 2005 10:59 AM
302man
Feb 13, 2002 06:06 PM
