Computer Chips & Tuners
mods that might require custom burnt chips
Old Apr 22, 2004 | 03:46 PM
The Phenom's Avatar
The Phenom
are there any aftermarket throttle bodies that wont require custom tuning, ive heard mac with the adjustable screw wont need one.
Old Apr 22, 2004 | 03:54 PM
openclasspro's Avatar
openclasspro
aftermarket mass air flow sensors need custom burns, throttle bodies do not
Old Apr 25, 2004 | 08:28 PM
sulconst2's Avatar
sulconst2
even granatelli's maf? thought they were calibrated not to mess with ford ecm.
Old Apr 25, 2004 | 08:34 PM
openclasspro
- after any aftermarket maf is installed you should dyno with a wideband 02 to get air -flow readings
Old Apr 25, 2004 | 08:40 PM
sulconst2's Avatar
sulconst2
an expensive tool for a do it yourselfer. installed a aem brute force intake and the maf is the smallest part in line to the throttle body. looking to purchase one but hate to burn my new superchip. hoping the granatelli would work
Old Apr 25, 2004 | 11:06 PM
FTE Ken's Avatar
FTE Ken
If you use a calibrated MAF by itself its usually fine. If you use it with a chip you need to get a wide band O2 graph because its probably going to be too lean with a standard burn.
Old Apr 26, 2004 | 08:19 AM
sulconst2's Avatar
sulconst2
what would be the rough cost to burn a superchip for a maf sensor on a v10?
Old Apr 26, 2004 | 07:55 PM
FTE Ken's Avatar
FTE Ken
I don't put prices on the forums (except for specials), trying to keep it from becoming a catalog and instead keeping it as an information source.
All current prices here:
http://www.motorhaven.com/customer/home.php?cat=37
Old Apr 29, 2004 | 10:09 PM
okladrop's Avatar
okladrop
Question
Hello Ford Bros, I see that you are talking about 02 and lean burn, I and issue and I hope that you all my be able to help me out.
My 97 F-150 has over 119,000 miles and I have add coldIntake,75mmTB,MAF, F.M. catback,w/20in shoes and I'm now adding a stage 3 chip.
Will I need to change my stock 02, and if so change it to what?
Thanks
v/r Waiting
Old Apr 30, 2004 | 05:47 PM
openclasspro
be a good idea to change it out- and have it dynoed with air fule wide band done on it so ken can richen tune for that aftermarket maf
Old May 2, 2004 | 01:00 AM
FTE Ken's Avatar
FTE Ken
You don't need to change the O2 sensor unless its gone bad from either failure or extensive rich burning for a lot of miles. You need the computer programmed for the mass airflow sensor. The chip needs a custom burn, and wideband O2 reading on dyno will help a lot but is not 100% required if you have a calibration sheet with the MAF.
Old May 2, 2004 | 01:35 AM
okladrop's Avatar
okladrop
Thanks for the info.
AllaboutMPG
18
Oct 6, 2014 01:26 PM
pro-car
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 13, 2008 01:12 AM
sancochojoe
Jun 6, 2006 07:46 PM
mcne2026
May 19, 2006 02:56 PM
rsjohnsn
Modular V10 (6.8l)
21
Mar 12, 2002 09:33 PM
