Wet vs dry Intake pros/cons?
Old 03-28-2017, 08:57 PM
Kyle Wood's Avatar
Kyle Wood
Kyle Wood is offline
So ive been wondering what the pros and cons are to wet and dry intakes if their are any.
Only pro i could see is that the coolant running through the intake might cool incoming air but im just taking a guess.
Old 03-29-2017, 09:09 AM
lee's Avatar
lee
lee is offline
I think you have this backwards: Once the engine is up to temp, the coolant will be ~195*. Air/fuel going through the carb will be is few degrees BELOW the ambient air temp so,... the coolant will HEAT up the air/fuel mixture not cool it.
If you live in a cold climate the heat from the coolant will heat up the intake and possibly help prevent the carb from icing up.
Old 03-29-2017, 10:41 PM
PapaBearYuma's Avatar
PapaBearYuma
PapaBearYuma is offline
That's actually a great question! I'd never considered WHY some intakes are dry while others are wet, just that some ARE.
The intake doesn't need the cooling-the block and the heads (where the combustion happens) is the part that generates all the heat, and even 195 is downright chilly compared to combustion temperatures.
I think the reason some intakes are wet is just how the engineers decided to route the coolant on that engine.
PapaBearYuma
oops-duplicate
Old 03-30-2017, 06:14 AM
Fordworth's Avatar
Fordworth
Fordworth is offline
You got it. It's mostly just a matter of architecture. Of course this is not to be confused with wet vs. dry in fuel injected applications where a wet intake means that both fuel and air flow through the manifold, typically in TBI where the injectors are in the throttle body. A dry manifold means that only air flows through the runners and the fuel is injected down stream near the ports in the head.
Old 03-30-2017, 06:31 AM
Kyle Wood's Avatar
Kyle Wood
I was thinking it was just typically how they decided yo route the coolant around the block too. But i thought that maybe their might be some type of added benefit for doing this.
dive2663225
02-26-2017 05:48 PM
F-250 restorer
05-14-2011 08:29 AM
ford_man
24
01-15-2007 02:19 PM
Rockledge
3.0L V6
07-14-2003 01:53 PM
bonzi88
03-18-2002 06:20 PM
Quick Reply: Wet vs dry Intake pros/cons?
