1994 Headlight Switch Removal
Old Oct 25, 2002 | 07:03 AM
chaynes171's Avatar
chaynes171
Simple question, how do you replace the headlight switch? Does the dash have to come out? Special tools needed?
Old Oct 25, 2002 | 11:16 AM
dlcslcman's Avatar
dlcslcman
[updated:LAST EDITED ON 25-Oct-02 AT 12:16 PM (EST)]
If memory serves me right, You should just have to remove the facia by popping it off and the switch should have mounting screws. I can't remember exactly, but I seem to remember the **** for the switch being alittle tricky to get off. A pin or clamp????? I do remember it wasn't that difficult. What happened, did all the parking lights go out and all that remained were the headlights?
Dave
Old Oct 25, 2002 | 09:17 PM
craterjoe's Avatar
craterjoe
if you look at the shaft portin of the headlight **** (it may be easier with the lights turned on) there should be a notch on one side.
Using a small screwdriver or similar instrument in the notch it will hit a smazll tab of metal when slid rearward or the same direction as the switch goes when you turn on the lights. the facia of the dash just pops out with careful and gentle persuasion with as flat tool a butter knife or putty knife works pretty well for this. look around carefully for other visible attaching screws before yo try to pop the facia off so it doesnt become cracked. as for the switch is attatched with screw, probably torx, and once removed just diconnect the plug and read this post backwards to reinstall everything. the ***** just push on after you line up the flat spots in the **** and on the shaft.
craterjoe
Old Oct 26, 2002 | 01:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
mojavearcher
Feb 14, 2017 10:33 AM
cliffhanger228
Sep 2, 2015 04:59 AM
TallTexan
Sep 26, 2012 07:57 PM
Michael1181
Feb 8, 2011 03:46 AM
HowieE
Electrical Systems/Wiring
Nov 11, 2009 11:07 PM
