81 f150 driveshaft problems
Old Apr 18, 2004 | 12:50 PM
81fordf150's Avatar
81fordf150
Exclamation 81 f150 driveshaft problems
I recently had a u-jjoint break while driving and my driveshaft was dragging on the ground the bad way where the front was digging in because it broke on the differential side. It is a 4 wheel drive. When i went to fix it the driveshaft is now an inch or more too short and wont fit. Is this a bad thing or did it just get compressed? and is it fixable?
Old Apr 18, 2004 | 01:36 PM
Jimbare's Avatar
Jimbare
all alone in the world
the slip joint is jammed in tight. you will probably have to pull the shaft out and use a hammer to get it freed up.
you should probably have the shaft looked at by a drive shaft shop. if it hit that hard it is probably bent. lay it on the driveway and roll it, if it is bent it may show up doing that.
jim
Old Apr 22, 2004 | 08:25 PM
dave62380's Avatar
dave62380
dave62380
just like jimbear said it is probably jammed in there so give it a pull.
and a little advice you might want to invest in some dana spicer u joints soon.
Terpfords
May 17, 2009 02:10 AM
Kuskoal
Nov 1, 2008 09:29 PM
TMattson
Sep 3, 2008 02:52 AM
piperig78
Offroad & 4x4
34
Jan 30, 2006 04:59 PM
Charlie's Truck
Mar 5, 2003 05:12 PM
