Overdrive??
Old Oct 28, 2002 | 09:39 AM
Gr8ride's Avatar
Gr8ride
Overdrive??
Howdy yall,
I have a 93 F250 7.3L w/ auto E4OD.
Everybody says don't haul in overdrive.
My question is why? Is it because
the transmission temps get to high?
What’s considered to high?
If I added a heavy duty transmission
cooler a mag-hytec pan and a
temp gauge, would I then be able to
haul in overdrive?
Also how do you tell if you have a
super duty?
Any thoughts or suggestions would be
appreciated.
Thanks,
Gr8ride
Old Oct 28, 2002 | 06:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Overdrive??
There is no reason you can't tow in overdrive, unless it is frequently shifting in and out of overdrive.
Ford says you can tow in overdrive. It's in the owner's manual.
Old Oct 29, 2002 | 07:05 PM
Original Mr Plow's Avatar
Original Mr Plow
Overdrive??
Old Nov 2, 2002 | 06:05 AM
argve's Avatar
argve
Overdrive??
> Howdy yall,
>haul in overdrive?
>super duty?
>appreciated.
> Thanks,
> Gr8ride
I tow all the time in OD unless she starts hunting for gears, then either back off the throttle of drop down a gear to stop the hunting. The hunting will generate a lot of heat. I tow a 4000lb boat and a 9000lb TT (not at same time) and I just put it OD and go. I have put 100k miles on my E4OD. Just run a aux trans cooler, or as I do couple it with a aux trans filter set up.
Gr8ride
Dec 4, 2006 06:38 PM
Gr8ride
Aug 23, 2005 04:09 PM
Gr8ride
All Things Towing
Apr 8, 2004 10:52 AM
Gr8ride
May 20, 2003 05:23 PM
Gr8ride
Apr 20, 2003 09:30 AM
