Transmission Cooler??
Old Mar 7, 2003 | 09:46 PM
Gr8ride's Avatar
Gr8ride
Question Transmission Cooler??
Howdy,
I have a 93 F250 7.3L diesel w/ auto E4OD.
I want to be able to haul my 3000# empty weight trailer in overdrive. I am having trouble figuring out what size after market transmission cooler that I should get. The trucks GVRW is 8800#, the trailer can haul 10000#. So that would be an 18,800# GVRW. So would a 20,000# GVRW cooler work? Or do I need to go bigger? Right now I only have the transmission cooler that’s in the radiator and a very small external cooler, I want to stop using the radiators cooler and only use the after market cooler.
I'm also looking at getting a transmission fluid filter, I wanted to get your opinion on it first.
Also, where do you guys recommend putting the sensor for the transmission temp gauge and who makes a good gauge and sensor?
Any help or comments would be greatly appreciated.
Thanks,
Gr8ride
Old Mar 8, 2003 | 10:11 AM
Flash's Avatar
Flash
Here is the dilema that you face, you can over cool your E4OD and it won't function correctly especially in the winter. I would be looking for a cooler rated around 10,000, run the hot line from the tranny to the cooler and then back into the radiator. In the summer, you should have sufficient cooling and in the winter you should have enough heat. Or, you can bypass all that and get a cooler rated at 20,000 with a thermostat. They cost more and you have more parts but it may be what you are looking for. NAPA can get you all the goodies you want.
Old Mar 9, 2003 | 10:04 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The stock coolers should work fine for towing 3000 pounds, even in overdrive.
Why would you want to remove the radiator cooler? It removes a lot of heat from the transmission. It's especially useful at low speeds, such as backing a trailer.
Old Mar 9, 2003 | 11:28 AM
flyboy2610's Avatar
flyboy2610
Unless you have a busted cooler tube in the radiator, the recommended practice is to run them in series, through the radiator and then the afermarket. Like was said, if you overcool the fluid your tranny won't shift properly.
Old Mar 9, 2003 | 07:04 PM
Mattman1's Avatar
Mattman1
As for the inline filter; Ford has one that is recomended at every rebuild or torque converter replacement. If you want the temp sansor, Perma-cool has one that uses an oil filter spin-on type. This can be ordered from summitt for $80. I just won one on Ebay for $55. Seems pretty trick.
Old Apr 5, 2004 | 10:16 AM
cinchitup's Avatar
cinchitup
Transmission Cooler
Mark Kovalsky,
I can't leave you an email because I don't have the ability to yet....not enough posts. I was wondering if you could recommend a transmission cooler manufacturer to me. I just purchased a 2004 F-350 Crewcab DRW and pull a horse trailer that weighs roughly 16K. I want to do everything possible to protect my transmission so any suggestions you can make would be greatly appreciated..
Old Apr 5, 2004 | 06:42 PM
jim henderson's Avatar
jim henderson
BTW the perma cool filters and temp sensor can be a beach to find a place to mount.
I finally mounted mine on the plastic fender well underneath the Winshield washer tank. Be sure to add a ground wire to the metal mounting bracket so you have a complete electrrical circuit to run the gauge. Also be sure to use that teflon tape to seal all the connections. ATF is very good at finding leaks and then it makes a mess and then it eats your rubber body bushings and other rubber stuff. There is not a lot of room under the tank so measure carefully. Worst case you can use a short filter as mentioned in the kit.
Good Luck,
Jim Henderson
Old Apr 8, 2004 | 10:52 AM
Toyman's Avatar
Toyman
With the trans being electronic you can also run into problems with the computer, not knowing when to shift, or a firmer shift. It is designed to read the temp of the trans and work from there. I would add a larger cooler and replace the factory small one, but keep it running through the radiator so it will get to operating temp.
Toyman
99expyTN
Sep 20, 2013 04:00 PM
johaner78
15
Jul 31, 2012 06:37 PM
hhardradi
1997 - 2003 F150
Aug 3, 2011 02:49 PM
hhardradi
Aug 1, 2011 11:36 AM
Gr8ride
Nov 2, 2002 06:05 AM
