Light VS Heavy Duty?
Old Dec 3, 2006 | 06:15 PM
Gr8ride's Avatar
Gr8ride
Howdy,
I would like to know the difference between the light duty F250 and the heavy duty? and how do you tell them apart? is there a difference between the brakes or what?
Thanks,
Gr8ride
Old Dec 3, 2006 | 07:17 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The heavy duty truck has a one ton rear axle.
The frame is much thicker.
The rear axle is also equipped with bigger brakes.
All diesel equipped trucks are heavy duty.
Gassers can be either way.
Old Dec 3, 2006 | 09:01 PM
Gr8ride's Avatar
Gr8ride
I was thinking that the diesels were heavy duty but I wasn't sure.
Are there any other differences?
Thanks for the reply
Old Dec 3, 2006 | 09:19 PM
fellro86's Avatar
fellro86
The rear hubs on the axle are visually different as well. The light duty axles have semi floating axles. The flange is straight like a 1/2 ton, but with 8 lugs. The heavy duty axles have a full floating axle, where you can unbolt the axle and pull it out with the hub still in place.
Old Dec 4, 2006 | 12:24 PM
Gr8ride's Avatar
Gr8ride
Great info guys, that explains why I had trouble getting the right brakes last time around.
Old Dec 4, 2006 | 05:21 PM
catfish101's Avatar
catfish101
Depends the year also. The older "light duties " had single piston calipers on the front brakes. That is the givaway in the 70's and the alot of the 80's. I have seen full floating rear axles in older 3/4 ton "LD". My 79 does. Also the suspentions can be different from year to year. My 86 has heavier coil springs then does my 83 but the 83 has heavier rear leafs. Now the 86 is an extended cab and the 83 isn't. That may the reason. I can't speak for the late models but the older trucks could be anything almost. There are alot of differences between the 83's and 86's anyway.
Old Dec 4, 2006 | 05:25 PM
fellro86's Avatar
fellro86
Definitely differences by year... my dad's 84 250 4x4 has the one ton front hubs, while my 86 has the more common smaller hubs. Both are diesels...
Old Dec 4, 2006 | 06:38 PM
Hamberger's Avatar
Hamberger
You got the 3" shoes and drums on the diesel trucks in the rear. You need to be specific and specify 3" shoes. The light duty trucks only use 2 1/2" wide shoes.
Gr8ride
Mar 3, 2012 08:23 PM
Gr8ride
Sep 25, 2009 02:49 PM
Gr8ride
Sep 6, 2005 10:23 PM
Gr8ride
Aug 23, 2005 04:09 PM
Gr8ride
Apr 13, 2003 09:30 PM
