steering column manual shift re-installation
Old Apr 17, 2004 | 11:27 AM
ffautoclub
Guest
Posts: n/a
Thumbs up steering column manual shift re-installation
I need a diagram or some info on how to reinstall the manual shifter on the steering column for a 1966 Ford F-100. I think I have it but when I go to put the column back in I lose 2nd and 3rd gears. Any help on this subject will be greatly appreciated. Thank you Mark Dyer (ffautoclub)
Old Apr 17, 2004 | 07:53 PM
dusty64f100's Avatar
dusty64f100
Make sure the column is turned correctly. It should fall in to a notch of some sort. I had the same problem but if you turn it just a little in one direction, you should be able to feel it fall into the notch. Could be something else but this worked for me.
Old Apr 18, 2004 | 02:39 AM
daveengelson's Avatar
daveengelson
Posted earlier regarding 'steering column'. Intend to replace column bearings within next couple of days. If you have not gotten the problems solved i can post on how the column shift is set up. May want to disconnect the shifting forks and see if the problem is in the column. Getting the shifting levers crossed could cause a problem.
Disassembled column shift sometime back. If recall, the shifting tube is notched and aligns shifting arms, with the shifting lever. Could be mistaken. Suffer from short and long term memory loss. If weather permits intend to take my column apart tomorrow. Suspect you will get additional info. and suggestions before then.
dave
treverd
Jan 9, 2017 09:23 PM
69Flareside
15
Jun 4, 2016 12:08 PM
roadrash63
Apr 30, 2016 07:42 AM
bmac4020
Jan 4, 2014 05:47 PM
SuperDuty93
Apr 4, 2012 12:17 AM
