steering column?
Old Apr 1, 2012 | 11:45 PM
SuperDuty93's Avatar
SuperDuty93
steering column?
1974 F250 4X4, NON TILT COLUMN
Ok so i have alot of wobble in my steering coulmn. Part of the prob is that the non U joint end of the steering shaft below the column seems to have partly broken. Also, at the bottom of the steering column shaft, above the U joint end coming off the steering shaft, there is a little rubber grommet that seems to have somehow come out of the column?????
After that long story wich seems to lead to no question.lol Is there some kind of a rebuild kit for the coulmn? And how long would you guess it would take to pull the column and rebuild it? Then re-install it?
Old Apr 2, 2012 | 08:33 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Nope, no rebuild "kit" per se. You'll need to figure out which parts you need then see if they're still available.
Is your truck automatic or manual? It makes a difference.
Let me know which one you have and I'll post the exploded diagram so you can see what you're getting into.
Old Apr 2, 2012 | 12:55 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
All I remember seeing for a bottom support on these trucks is a roller bearing that is in a plastic cage that supports the shaft. I haveseen the tabs break off and the shaft is loose due to the plastic not clamping the column housing anymore, I guess the plastic could break off and the bearing is all that is left and it could be loose, possible.
Old Apr 3, 2012 | 10:14 PM
SuperDuty93
Its an Automatic
Old Apr 3, 2012 | 10:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by SuperDuty93
Its an Automatic
Here's the exploded diagram from the Ford parts catalog. Use the basic p/n's and let me know which parts you're looking for and I'll see if i can locate them.
Click on the .pdf link to view.
Old Apr 3, 2012 | 11:02 PM
SuperDuty93
3518. what is it?
Old Apr 3, 2012 | 11:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
3518. what is it?
Sleeve, steering column tube bearing
74-up from s/n S40,001
D1AZ-3518-A
Salem Motors Inc, Crookston, MN has 1 (218) 281-1138
Old Apr 4, 2012 | 12:17 AM
SuperDuty93
Is that a FORD dealer? And to order it do i need to call i assume...
NMFirstF2504X4
Oct 31, 2013 08:18 AM
headhoncho
Aug 28, 2007 09:10 PM
satx77stepside
Nov 12, 2005 04:01 PM
Seifferlein
Aug 11, 2005 08:53 PM
79_ford_400_guy
May 20, 2003 02:52 PM
