Small Block ID
Old Apr 14, 2004 | 02:47 PM
pessrodc's Avatar
pessrodc
Exclamation Small Block ID
I have a 74 Bronco that does not have the original 302 engine. I cannot find any numbers on the engine to identify it. It has an after market intake and carb. Can anyone advise me on how to identify the engine size and year?
Old Apr 14, 2004 | 03:15 PM
lvmoose007's Avatar
lvmoose007
Climb underneath, and check out the block, around the back of the oil pan. On the side of the pan rail, on the block( on the starter side?...oops, getting old), you should see a casting number: it should be a C8AB or something similar...C, D, E, F, will be the the decade of casting, the number afterward will be the year...and the A part is the vehicle line...etc...post back with this info.
Old Apr 14, 2004 | 08:05 PM
TheWiz427's Avatar
TheWiz427
Once you get the numbers check here! http://www.pacificnet.net/~fastoso/castingcode.html
Old Apr 14, 2004 | 09:14 PM
Longneck's Avatar
Longneck
That link only lists engines made through the 80's, can I assume that they just continued to the next letter in the alphabet for the 90's?
Longneck
Old Apr 15, 2004 | 06:03 AM
TheWiz427's Avatar
TheWiz427
Yes thats all you have to do!
Old Apr 15, 2004 | 08:48 AM
Longneck's Avatar
Longneck
Cool, that's what I thought, but I've noticed I only get in trouble when I'm thinining
Longneck
Sam's1967
Dec 5, 2016 04:09 PM
John Enger
Sep 30, 2016 07:59 PM
Try this Ford
New Member Introductions
Feb 12, 2016 04:16 PM
walksLikeBear
1983 - 2012 Ranger & B-Series
Aug 17, 2015 01:31 PM
daviddennis
Dec 6, 2004 02:22 PM
