Compression Ratio Vs Pump Gas
Old Apr 14, 2004 | 01:21 PM
Jolbca1962's Avatar
Jolbca1962
Question Compression Ratio Vs Pump Gas
Hi allfficeffice" /><O></O>
I am building a 347 stroker for my truck. I am using ford E7E heads that have larger vales 1.9 int, 1.6 ext. The intake and exhaust has been ported as well on these heads. I am using a HO 5.0 liter block and roller isky towing cam Part#: 371252/257 . I am not going to tow with this vehicle except for the occasional trip once or twice a year. My question is should I us a different piston since the current Kieth Black (KB246) will bring up the compression ratio to 10:1 and I need to pass the dreaded smog test a couple of years from now. Please let me know your recommendations and I look forward to your response.<O></O>
Old Apr 15, 2004 | 12:50 PM
jimandmandy's Avatar
jimandmandy
High compression will not hurt your smog numbers and may actually help because of greater combustion efficiency. You should be ok with premium fuel and stock spark advance.
Jim
