DOWNPIPE???????
Old Dec 3, 2002 | 08:47 PM
79CEEJAY's Avatar
79CEEJAY
DOWNPIPE???????
Can I add a 3.5" downpipe and keep the stock exhaust? Do you still get the same results....lower egt's or does this just defeat the purpose? I want to retain the stock exhaust if possible, but want the larger down pipe. Any help, ideas, anything????
Old Dec 3, 2002 | 08:56 PM
Quadzilla's Avatar
Quadzilla
DOWNPIPE???????
It would be like putting headers on a gasser, but keeping the stock exhaust system. There is an improvement, but not as much as if you replaced the whole thing, and removed the catalytic convertor at the same time.
Quadzilla
'95 F-350XLT Crew Cab SRW 4X4 PSD, 35X12.50X16.5's, Limited slip 4.10's, Hypermax downpipe, gutted EBPV, "Catless" in Seattle, "Renegade" 4" exhaust system, CTFD sticker, Air bags on all four corners, TYMAR intake, shimmed fpr, Diablo Delta chip, Fumoto valve, Autometer pyrometer, Sonnax valve, Tricumulator springs, Tru-Cool, HX mod, Magnefine tranny filter,
4R100 pan, Red Line synthetic in transfer case and both diffs, reverse shackle kit.
And a wish list that gets longer every day.
(Thank God for a wife that likes big trucks.)
For pictures, click here: http://community.webshots.com/user/quadzilla100
Old Dec 3, 2002 | 09:01 PM
rsjohnsn's Avatar
rsjohnsn
DOWNPIPE???????
I may be wrong and if I am someone please correct me but I think that your downpipe is already a 3.5 incher.
Scott
Old Dec 3, 2002 | 09:24 PM
79CEEJAY's Avatar
79CEEJAY
DOWNPIPE???????
>Scott
It could be. I haven't measured it yet. I guess this means I will be looking at a 4". My main reason is to lower egt's with my SCMT on the 80hp setting. I assume that after the heat disperses through the down pipe, the gasses should?? be noemal by the time they hit the rest of the plumbing....how close to being wrong am I?????
Old Dec 3, 2002 | 09:26 PM
79CEEJAY's Avatar
79CEEJAY
DOWNPIPE???????
>Quadzilla
>filter,
Quadzilla, I know your wish list is getting longer, but it seems to me that the mods already completed gets longer too!!!! Sounds like a bad PSD to me
Old Dec 4, 2002 | 09:41 AM
bricot's Avatar
bricot
DOWNPIPE???????
It may be that the stock downpipe is 3.5" but look at the shape, the thing is almost flattened, not sure why they thought they had to pancake the thing so bad from the factory. I replaced mine with a 3.5" downpipe I got off this site and it was perfectly round, made a noticeable difference.
Old Dec 4, 2002 | 10:50 AM
rplett's Avatar
rplett
DOWNPIPE???????
>difference.
Is a non-flattened downpipe just a bolt-on installation or do I have to start cutting and bending things to get clearance? My '97 F250 doesn't have a lot of room between the engine and firewall.
rplett
Old Dec 4, 2002 | 01:33 PM
JoeBoost's Avatar
JoeBoost
DOWNPIPE???????
As far as i am aware , installing a bigger downpipe isnt rhe easiest thing in the world to do. Heard stories about people "beating" their firewall for clearance...
Old Dec 4, 2002 | 01:40 PM
bricot's Avatar
bricot
DOWNPIPE???????
[updated:LAST EDITED ON 04-Dec-02 AT 02:42 PM (EST)]You'll have to cut the old downpipe to get it out, the replacement is a two piece.
There is a lip where your firewall and body meet that may need to be trimmed or bent a little especially if you go with a larger downpipe, still nothing major.
Old Dec 4, 2002 | 03:51 PM
Distinctive Dave's Avatar
Distinctive Dave
DOWNPIPE???????
Dpotts94
23
May 27, 2013 12:30 AM
jcwichman
Jul 30, 2009 10:06 PM
rchouser
Sep 7, 2007 08:36 PM
Pablo69
Feb 13, 2006 08:44 AM
smeezy
Nov 17, 2004 01:17 PM
