My volts meter will bounce back and forth, and headlights will flicker when i am sitting idle or am parked, but once on the gas needle stays at around 14 and lights quit flickering. is this an alternator issue? wasnt sure as it starts fine every day and battery always has a good chage on it. thanks for any help.
when this happends do you have your headlights on and the fan speed set to high, ussually with that kind of voltage will cause the your lights to dim a little at idle with any car
yes but it does it during the day also with nothing on. actually does it less at night with the lights on. but the lights have a sorda strobe effect when ideling or in park.
Ok,The first question I have to ask,hopefuly you have a tack,what is your idle rpm,alot of times the idle may be too low and that can cause this to happen,and by the way I am a mechanic and cant even pretend to cook.
BTW>Welcome to FTE
I need to know,year,engine,and auto or stick?
