Replace Front Brake Rotors
Old Apr 14, 2004 | 01:18 PM
JojoManigbas's Avatar
JojoManigbas
I want to replace the front brake rotors on a 95 Explorer XLT 4.0l 4WD.
It looks like I need to remove the brake calipers to get to the rotors. It also looks like I just need to remove the 2 bolts that holds the brake caliper anchor plate. Once the brake caliper anchor plate is out of the way, the rotors should just come off (please correct me if I'm wrong).
My problem is that I could not unscrew the 2 bolts, even after 24 hours of applying penetrating oil. I’m afraid I might round out the head of the screw.
Is there a method to unscrewing them?
Is there like a pin or metal piece that needs to be set aside using a magnet (just like in older explorer) that would allow the screws to turn?
Any help would be greatly appreciated,
Jojo
