"charge" light flicker issue
Old Jun 21, 2014 | 09:38 AM
1981fordstepside's Avatar
1981fordstepside
I noticed today when driving after a few minutes the "Charge" idiot light flickers on and off randomly. Truck ran fine and starts fine. The light stops flickering when I put the head lights on. Am I correct in assuming there is an alternator issue maybe a voltage regulator and when I turn on the lights it draws enough power to keep the charge light from coming on?
Old Jun 21, 2014 | 12:06 PM
CountryBumkin's Avatar
CountryBumkin
It sounds like something is wrong. I would start by putting a volt meter on the battery (first with engine off) and seeing what the charge rate is a 1000 rpm with headlights off and on.
Old Jun 21, 2014 | 12:34 PM
Franklin2's Avatar
Franklin2
Check the ground to the regulator case. I am assuming you are working on a 81?
Old Jun 21, 2014 | 12:43 PM
1981fordstepside
I don't have much experience with testing electrical systems.
With a voltage meter would I touch the ground and power to case from bat and read voltage? Should be between 12-14?
Old Jun 21, 2014 | 01:06 PM
JimsRebel's Avatar
JimsRebel
I have one of these to trouble shoot issues like these. about $3 from Hong Kong
http://www.ebay.com/itm/Digital-LED-Auto-Car-Truck-Cigarette-Lighter-Volt-Voltage-Gauge-Meter-12V-24V-/360736213678?pt=Motors_Car_Truck_Parts_Accessories&hash=item53fd8dcaae&vxp=mtr
Old Jun 21, 2014 | 01:11 PM
JimsRebel's Avatar
JimsRebel
I have also see this happen as the ALT brushes at worn to the limit. ~$5 is a cheap fix.
Duralast/Alternator Brush (FX42) | 1981 Ford F150 1/2 ton P/U 4WD 6 Cylinders E 4.9L 1BL | AutoZone.com
Damifiknow
Aug 14, 2015 03:50 PM
smacmybup
May 2, 2012 03:17 AM
79str8six
Mar 7, 2011 10:05 PM
ken's 80
Electrical Systems/Wiring
Sep 2, 2008 05:51 PM
JesusRocks
Feb 28, 2008 09:16 AM
