360 FE harmonic Balancer
Old Apr 9, 2004 | 12:30 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Question 360 FE harmonic Balancer
I am in the process of rebuilding a 360 for my 1969 Ranger. I am down to the harmonic balancer. The rubber on the origional one is cracked and has a few small chunks taken out. Is it ok to reuse it? If not where can I find one that wont cost me 2 to 3 hundred $$$. By no means am I building a race engine. I have called all parts stores in my area and even Ford, no luck! I found one on line for about $80.00, But it is for a 390, will this work?
Old Apr 9, 2004 | 01:15 PM
Mike G's Avatar
Mike G
A 390 balancer will work for your needs. You will probably not spend less than $60 unless you take a trip to the salvage yard (your call). Take a look at DSC Motorsports or check with your local guy at the machine shop, mine carries several options.
Welcome aboard --Mike
Old Apr 10, 2004 | 07:24 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Thanks Mike!
teched
Apr 1, 2016 12:06 PM
jvmcc
Nov 7, 2015 02:44 PM
taylor90
Feb 22, 2012 04:30 PM
MIKEDEL
Dec 15, 2011 06:43 PM
blackokc
1978 - 1996 Big Bronco
Nov 19, 2001 09:10 PM
