Modular V10 (6.8l)
unhooking battery to reprogram , why
Old Apr 9, 2004 | 08:47 AM
redbull660's Avatar
redbull660
I have heard that unhooking the battery every so often will help the computer. I have a 99 f250 with a v10. its completely stock with 63000 miles on it. How long should the battery be unhooked. and what will it do thanks
Old Apr 9, 2004 | 09:01 AM
Bob Ayers's Avatar
Bob Ayers
First, welcome to FTE!!!!!
I've never heard the term "helping the computer" before, but unhooking the battery is a way of resetting error codes that may have been set, throwing a CEL (Check Engine Light). There is a memory in the computer (PCM) that is always powered (even with the key off), and can be reset
by unhooking the negative battery terminal, turning on the
headlight switch, and waiting 10-15 minutes...
Old Apr 9, 2004 | 04:51 PM
jcrice's Avatar
jcrice
There are those who believe that resetting the PCM will force the system to "relearn" timing curves, etc. While this is true, it does this all the time anyway, and resetting it does nothing to help performance. The only reason you would want to reset it would be to clear an error code like Bob said. I've never seen a need to turn on the headlight switch, though.
Old Apr 9, 2004 | 05:24 PM
Bob Ayers's Avatar
Bob Ayers
Turning the headlight switch on just provides a current path to discharge the decoupling capacitors on the unswitched 12V, internal to the PCM. The faster these capacitors discharge, the quicker the PCM will reset.
swampfire79
Feb 11, 2012 02:40 PM
ttttmaxx
Jul 26, 2010 07:09 AM
bigbubba87
13
Feb 7, 2009 10:04 PM
AirTran
Nov 28, 2005 10:26 AM
ss10
Sep 30, 2004 09:35 PM
