gas oder in oil
Old Apr 5, 2004 | 08:05 AM
TDELONG83's Avatar
TDELONG83
gas oder in oil
i have a 1994 e150 with the 351 engine i have 130,000 and have had no problems up to now. i have a miss that is worse when gasing the engine. i have checked the oil and found an oder of fuel in the oil. any ideas ?
Old Apr 5, 2004 | 11:59 AM
blue_mule's Avatar
blue_mule
Sounds like a sticky or stuck injector.. Dumping WAY too much fuel in cylinder and by-passing rings...
Old Apr 5, 2004 | 02:44 PM
TDELONG83's Avatar
TDELONG83
thanks that would explain why the motor runs so bad now just try to find the bad injector
Old Apr 5, 2004 | 03:13 PM
blue_mule's Avatar
blue_mule
Injectors can be checked with an Ohnm meter... If you dont have one Check the spark plugs first..
a wet, or gas fouled plug is a sure sign...
Old Apr 5, 2004 | 06:44 PM
TDELONG83's Avatar
TDELONG83
thanks i will try a tune up befors checking the injectors..
Old Apr 6, 2004 | 07:13 AM
Slade901's Avatar
Slade901
Don't forget to check the spark plug wires itself for scrapes and probably running on the engine block as it causes the spark plug not to fire or fire poorly. Those fuel mixture doesn't get burned and will pass through the piston rings and contaminate the oil and you need to replace the oil as soon as possible as well since fuel thins the oil.
Old Apr 6, 2004 | 03:47 PM
TDELONG83's Avatar
TDELONG83
thanks for all the help
Primetime1
Sep 23, 2016 10:16 PM
hosshoss2674
1978 - 1996 Big Bronco
May 18, 2014 10:46 AM
ken1960
6.7L Power Stroke Diesel
15
Dec 4, 2013 09:53 PM
mike240zt
16
Jan 13, 2008 04:08 AM
Pablo-UA
Aerostar
Nov 27, 2007 02:45 AM
