Sponsored by: Auxito
Stalling Problem
Old Apr 1, 2004 | 09:49 PM
Ford356's Avatar
Ford356
Stalling Problem
I have a 1997 Ford F-150 5.4L with 106,000 mi. I runs great with one exception. Once in a while when I have been driving it in a certain throttle position for some time (like going down the freeway), when I let off of the throttle it will just idle down and stall. Once it does that it will continue to stall every time I allow it to until I shut it down for a while. It only does this occasionally. Someone please help. Thank You in advance.
Old Apr 1, 2004 | 09:53 PM
rednexandbeer's Avatar
rednexandbeer
hey i have a question abouit a 1990 f 150 can any one here help me out?
Old Apr 1, 2004 | 09:57 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
Thread moved
Maybe have a look at the text underneath the title of the General Conversation forum.
Old Apr 1, 2004 | 10:04 PM
King Triton's Avatar
King Triton
Well there are a few different things that it could be,iac that would be your idle air control,vacuum leaks,carbon build up.So my first question would be,when this happens to you,does your ck eng light come on.If so,you will need to run up to autozone and have them get the codes,so I dont send you in the wrong direction.This could also be EGR related,but lets see if we can get codes first.
Old Apr 1, 2004 | 10:06 PM
King Triton
Ask away
And gee mil1ion,your fast,by the time I read this in gc and typed in my reply you had already moved it.
Old Apr 1, 2004 | 10:22 PM
Ford356's Avatar
Ford356
Hi there,
Thank you for your response. Where would the carbon build up be? I believe that my friend who I bought the truck from changed the idle air control. After it stalls the check engine light is on but when I start it up it goes away. What kind of codes do I need to get? Also, to save myself from sounding like an idiot when I go to Autozone, what exactly do I ask for?
Thank You
Old Apr 1, 2004 | 11:27 PM
King Triton
When you go to autozone,just tell them you are having problems with your truck and ask them to pull the codes for you,they will know what you are talking about,dont worry,they wont think you are dumb.It takes a scanner to pull the codes from your ECM=Electronic Control Module,and my scanner cost over $2,000 so,they realize that the average guy who wants to fix his own truck is not likely to own one.They are happy to do this for you because,afterall you will probably need a part or two,so it is good for their biz.And for the carbon question,it may have something to do with carbon build-up on the egr valve,making it stick open,which it is not supposed to do when returning to Idle.The EGR system is used to help reburn exhaust gases to lower emmisions,but only works after the engine is warm and above a certain RPM.If the valve is stuck open at idle,it will let exhaust gases smother the air fuel mix and cause a stall problem.But there are alot of other things it could be too.Like a flat or dead spot in the TPS=Throttle Posistion Sensor,but I dont want to overwelm you or send you in the wrong direction,so try and get the codes first.
Old Apr 2, 2004 | 10:48 AM
FourthFordTruck's Avatar
FourthFordTruck
On the carbon issue, carbon also builds up directly below the EGR Valve
in the EGR ports. The two dime-sized ports completely close up with carbon.
You will find multiple threads addressing this fix, do a search.
If you change the EGR, clean the ports. Changing the EGR is pretty easy, cleaning
the ports is harder, because you have to remove the throttle body.
Did mine last week, changed the EGR Valve,
cleaned the EGR ports, changed the IAC, new alternator.
Runs pretty good again. Cleared the codes one by one with new parts
and EGR port maintenance. It was worth every bit of effort in exchange
for personal satisfaction and lots of saved dough.
SuperDutyScaler
Jun 27, 2014 10:29 AM
harry.knox
Mar 9, 2013 09:01 AM
94rangersplash
1983 - 2012 Ranger & B-Series
Dec 1, 2011 07:40 PM
Glenn_May
1978 - 1996 Big Bronco
Jan 13, 2006 09:51 PM
351mford
29
Jan 7, 2004 12:19 AM
