CB Help
Old Apr 1, 2004 | 01:22 PM
Tmitchell's Avatar
Tmitchell
Exclamation CB Help
I Have Ran my Cb wires but im not sure where to run the antenna wire so it gose to the bed. the Cb Radio is located on the pasenger side of the cup holder on my 99 Ford Ranger XLT... i would like any or all help that can be given to me
Old Apr 1, 2004 | 01:50 PM
98xlt4x4's Avatar
98xlt4x4
You can run the coax through the firewall, and then under the body, using zipties to secure it to the frame. I think I've seen someone mention that there is a rubber plug in the back of the passenger compartment too, but never seen it myself?
Should be some posts on here about finding a hole in the firewall. I believe you can squeeze it through a grommet near the hood release cable... Hope you figure it out
Old Apr 1, 2004 | 03:42 PM
rangerdriverforlife's Avatar
rangerdriverforlife
There are rubber grommets located either on the back of the cab, or on the bottom of the cab behind the seats (under the carpet of course). To locate these, it is easier to look from the underside of the truck. Use cable ties to secure the coax to the frame, or any other sturdy member. There is usually one on the driver side and one on the passenger side.
Old Apr 1, 2004 | 07:08 PM
WXboy's Avatar
WXboy
Yeah, like he said there are access holes in the bottom of the cab at the rear. Just pull out those rubber grommets and there you go. Fords are the easiest trucks in the world to put radios and stuff in. I love it.
Old Apr 1, 2004 | 07:19 PM
rangerdriverforlife
Before you throw those grommets away. Cut the middle out of them and slip the coax through, and put them back in. You can use some type of silicone sealer to seal the grommet completly once it is installed. This will save wear on the coax, and keep the hole as watertight as possible. By the way, what kind of antenna did you get? I have toyed around with a few different ones and finally settled on dual glass mount antennas.
Old Apr 1, 2004 | 07:29 PM
WXboy's Avatar
WXboy
rangerdriver...good advice. I also kept my grommet and sealed it up with silicone. i forgot to mention that. it keeps your carpet dry that way too!
Old Apr 1, 2004 | 11:05 PM
cow_boy104's Avatar
cow_boy104
If you have a ext cab, pull up the carpet behind the driver, or pass seat. There is a small gomment under there thatyou can use. heres a pic of what it looks like from under the truck. Its right above the frame rail.
soupy1957
2009 - 2014 F150
Jan 6, 2015 04:31 AM
Slayer09
Electrical Systems/Wiring
13
Jul 30, 2008 11:34 AM
skirk55
Nov 29, 2006 04:35 PM
devildog_0431
May 21, 2006 07:46 AM
jrs_big_ford_f150
Nov 17, 2002 08:12 PM
