Have a 2001 Ranger 4X4 extra cab, off road, it has the plastic extended bed guards, around the sides of the bed, and a bedliner. Do you know of any tool box that can fit on the bed without removing the guards.
Thanks
Reason: More info
I put a drop in liner in my 94, added cross bed box by just bolting it to the liner that fits over the edge of the bed. The box sits about 1.5-2 inches from the edge of the bed up front but still looks ok. I had to heat the liner in the corners due to their being rounded and the box square and push the box in to kinda form fit.
Another way is is you have the pocket holes on top of the bed is to get some of the large spring wall clamps fom a hardware store and install thru a hole in the box and then push down into the pocket hole where they spring open and lock when tightened.
^^^ is my truck. The black one isnt. I think he made, or had it made. But there is a company out there that is now making them for Rangers. I dont think it matters with which cab you have. All your doing to drilling holes in the roof to mount it.
Con-Ferr rack/tire mount/flooring kit/rear light tab
