2bbl to 4bbl adapters
Old Mar 29, 2004 | 01:13 PM
Redone's Avatar
Redone
I'm sure someone has already asked this question before however; considering there are tens of thousands of members and threads to match, I thought it would be faster to repost the question then to spend hours searching.
A friend of mine gave me a Holley 4bbl 600 cfm carburator that has only seen a few thousand miles of use. He wanted something bigger for his engine build and gave it to me thinking that I could use it someday. Well, can I use on a stock 351M with a carb. adapter? Are there any benefits? Would I lose my estimated 14 mpg highway figure?
I thought I read somewhere that with the right amount of intake velocity that this type of application would work just fine.
Thanks.
Old Mar 29, 2004 | 02:00 PM
74 F100 351m's Avatar
74 F100 351m
I put a 650 on a 400 and it's gitting better milage.
Old Mar 29, 2004 | 03:54 PM
Redone's Avatar
Redone
Good, but did you use an adapter or a new intake manifold with the new 4BBL carburetor?
Old Mar 29, 2004 | 04:34 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I've used a Carter 625 on my 400 with a Mr. Gasket (1955 I think) 2x4 adapter. It worked alright.. they are very holy so they can be hard to seal and keep sealed. I swapped over to a Edelbrock performer 400 intake and it made a world of difference.
Most carb makers don't like the use of 2x4 adapters (found this out after reading the fine print.. )
Old Mar 29, 2004 | 06:25 PM
scroob's Avatar
scroob
Adapters don't give you much improvement over a 2V, since you're still having to jam all that mixture down two manifold holes.
Old Mar 30, 2004 | 08:18 AM
Redone's Avatar
Redone
So, if I can get a new intake manifold, are there any made for EGR provisions? I have to have this on the truck in order to past the emissions test next year. Or would I be better off with a larger 2V carburetor?
Old Apr 1, 2004 | 10:11 AM
Bill_Beyer's Avatar
Bill_Beyer
Edelbrock makes the Performer EGR 4V p/n 3771 manifold which when installed with the included 2V adapter is CARB approved as a stock replacement part. If you remove the 2V adapter and install the 4V adapter you can mount any square bore 4V carb on it. Note: The Performer EGR is a 4V manifold which comes with a 2V adapter to make it emissions legal. The 4V adapter is available from Edelbrock or you can buy one from FoMoCo as well.
Old Apr 1, 2004 | 10:40 AM
packlet's Avatar
packlet
What bill said. But keep in mind the edelbrock 3771 is only smog-legal if you use the 4-to-2 bbl adapter and keep your stock 2-bbl carb. (at least here in Cali.)
This is because these motors (351m/400) never came with a 4-bbl from the factory. Of course, it might be simple enuf to swap out the adapter and carb between smog checks...
Old Apr 1, 2004 | 01:20 PM
78custom's Avatar
78custom
My truck came with a Holley600on it and it also had a Carb adapter. I'd go with a 4bbl intake for better milege and power.
Old Apr 4, 2004 | 06:17 AM
scroob's Avatar
scroob
"My truck came with a Holley600on it and it also had a Carb adapter. I'd go with a 4bbl intake for better milege and power."
But it wasn't stock.
Bear in mind that the simplest visual check is going to see the illegal 4V carb and that in CA, the visual inspection outweighs the tailpipe check.
In other words, they will fail you even if the tailpipe passed, if the parts don't match.
Salomon Trujillo
May 5, 2013 03:20 PM
e william
Dec 30, 2009 01:38 PM
funkoptimus
Feb 23, 2005 03:50 PM
culiv
Dec 13, 2004 06:13 PM
Redone
Apr 22, 2004 11:14 PM
