Sad for reality
Old Apr 20, 2004 | 08:52 AM
Redone's Avatar
Redone
Sad for reality
I've been contenplating the idea of swapping out my stock 2BBL intake for an aftermarket 4BBL but thought I'd better check with the state of Missouri first.
Well, after many phone calls I got the answer I did not want to hear. I was told that I must retain an EGR valve on my truck. Sure I can use an adapter plate when I get the state inspections done but I really don't want to swap out carburetors and such once a year just to pass the visual inspection.
So, what can I do now? I'm thinking about rebuilding the engine sometime this fall but would like to make some plans before I start buying parts.
Ideas? Spreads? Dyno numbers?
Thanks.
Old Apr 20, 2004 | 09:38 AM
beartracks's Avatar
beartracks
Get the Performer EGR from Edlebrock.
Old Apr 20, 2004 | 10:44 AM
Redone's Avatar
Redone
So, can I order the Performer #2171 and buy the 4V EGR adapter #8053 to fit on the intake manifold? Or do I order the Performer EGR and specify a 4V EGR adapter?
Old Apr 20, 2004 | 10:52 AM
Redone's Avatar
Redone
One more question. Will I be able to use my 600 CFM Holley carburetor with an Edelbrock product?
Old Apr 20, 2004 | 12:46 PM
packlet's Avatar
packlet
you want the #3771 w/ 4V EGR adapter.
and yes, you can use the Holley.
Old Apr 20, 2004 | 06:19 PM
Bill_Beyer's Avatar
Bill_Beyer
The #3771 comes with a 2V EGR adapter. You'll need to order the 4V EGR adapter seperately. It's designed for any square bore 4V carb.
Old Apr 21, 2004 | 10:07 AM
Redone's Avatar
Redone
Thanks for help guys.
Old Apr 22, 2004 | 11:14 PM
There Goes The Neighborhood's Avatar
If everyone recommends a 600 cfm 4bbl for a street 400, why not get the Performer EGR, and run the 2bbl EGR spacer with a 500 cfm 2bbl? Just as good of a top end, better low end, and good mileage. And it will pass visual with no problems. Just food for thought.
