Boost question
Old Sep 28, 2003 | 09:28 PM
ehumaui's Avatar
ehumaui
Question Boost question
I just finished installing boost and pyro guages. It took about 3.5 hours to install. I do have a boost question. I noticed at 1500 rpm the boost is about at zero. The only time I get the boost up is when I floor it and get the rpms up. Is boost related to rpms? At idle is the boost at zero?
Russell
Old Sep 28, 2003 | 09:36 PM
crashandburn420's Avatar
crashandburn420
at idle... the boost is zero. boost is relative to the amount of work that you are asking the truck to do. if you are parked and just floor the thing it will read about 5 psi. it doesn't require much for the truck just to rev the engine. if you are leaving from a stop it takes more. with a moderate-quick acceleration, you should see ~10psi ... at full bore, passing somebody, hauling tail you should see ~15psi more or less. these numbers will be higher if you have it chipped or programmed.
Old Sep 28, 2003 | 10:37 PM
ehumaui's Avatar
ehumaui
Thanks for the info. I thought the boost guage was broken or my line was pinched.
Old Sep 29, 2003 | 09:52 AM
Lucca's Avatar
Lucca
My readings are almost exactly like crashandburn's on my 99.
Old Sep 29, 2003 | 09:58 AM
crashandburn420
i did the same thing. you get the boost gauge hooked up and crank the beast over just to sit in the driveway and rev the heck out of it. i took mine apart twice before it dawned on me that i wouldn't get a decent reading unless the engine was under load. i am sure that many have done the same and just didn't mention it.
Ken99F350dually7.3
16
Oct 25, 2019 06:23 PM
Knucks
Apr 3, 2017 01:35 PM
036.0stroke
Oct 21, 2016 03:38 AM
schamsy
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
17
Oct 10, 2011 03:24 PM
79F150EFI
Oct 9, 2006 07:38 AM
