Spark Plug Gap
Old Mar 25, 2004 | 03:59 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Spark Plug Gap
What is the correct gap for a 94/95 302 truck motor? The truck is a 94, but the motor has a 95 firing order. I'm guessing it is a late 94 year model production. My Haynes says 44 thousands, but I have heard of 55 instead. Any thoughts?
Old Mar 25, 2004 | 06:01 PM
EPNCSU2006's Avatar
EPNCSU2006
Do you still have an emissions sticker under the hood? That would be what you'd go by if it is there. If not, .055" sounds right for the later model trucks. You could try both and see which one the engine runs best at as well.
Old Mar 25, 2004 | 08:23 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
i have the sticker, but it is so gunked up I cannot read it...when idling, it seems like the motor has a slight miss. if anyone has a picture of their sticker, I'd appreciate seeing it
Old Mar 25, 2004 | 09:20 PM
the_hetz's Avatar
the_hetz
Old Mar 27, 2004 | 07:31 AM
Icicle's Avatar
Icicle
every 302 I have worked on...my 89 mustang 5.0, And my wifes 82 302 (COMPLETELY different animals) were .044 for what thats worth
Old Mar 27, 2004 | 11:53 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
if it is .044, then what could cause my miss. It is only when idling. The plugs aren't fouled and I have replaced everything but the coil. When I get a spare 2-300 bucks I'll replace that to.
Old Mar 27, 2004 | 06:29 PM
umdstang's Avatar
umdstang
how r your plug wires, on my bronco with 5.0 there was a skip because the spark was jumping from wire to wire. try placing you wires farther apart
to test this open your hood at night, start the engine and see if you can see any sparks jumping, if not try spraying some mist of water and see if you can see anything
this was my problem
hope this helps
Brian
P.S. they were relativly new wires so new ones may do it
Old Mar 31, 2004 | 05:34 PM
walt80's Avatar
walt80
I got a MSD Blaster 2 coil from summit and it was only around 30 dollars.
TexasGuy001
15
Jan 20, 2019 04:15 PM
Trevor1
Dec 7, 2006 11:32 PM
Skylaneman
Jul 8, 2005 02:44 PM
Tylus
Apr 8, 2004 04:18 PM
taketheredpill
Aug 10, 2003 10:18 PM
