Need Help: Bad Idle !!!!!
Old Mar 20, 2004 | 03:41 PM
meck1's Avatar
meck1
The bad idle on my '87 F250 (300, of course) is driving me to drinking (more than usual). The truck runs great at speed, good gas mileage, and all that. When I let off the gas, though, it begins to miss and continues doing so after idling down to an idle speed. It feels like it's running on about 4 cylinders instead of six, loping along, very rough. No black smoke or such while it's idling rough, and it revs up quickly when I hit the gas. Any hints anyone can give me of what to check will be appreciated. I've gone over the basics, but I'm ready to start again,
Thanks
Old Mar 20, 2004 | 10:56 PM
AJ Goss's Avatar
AJ Goss
First thing to check is that IAC valve on top of the throttle body. They get gunked up and don't flow as much air into the intake as they should. Take it off and soak it in carb cleaner.
Old Mar 21, 2004 | 05:42 PM
ALSAIR's Avatar
ALSAIR
I got the same exact problem with my motor!!! It start's in the morning with a slight shake to it, but when it get's to temp it idles so rough, like it's missing (it's not). My throttle bodie is cleaned, no check engine light, nothing. 20,000 miles on re-build. The only conclusion I can come up with is the cat is plugged up, causing a high back pressure at idle, worse when warmed up!! Give it a little throttle and she purr's like a kitten. ****'es me off!!
Al
Old Mar 21, 2004 | 06:41 PM
rhetor's Avatar
rhetor
check your TB gasket.
Mine was so thin it got sucked in and was a pretty bad vacuum leak.
Old Mar 21, 2004 | 09:50 PM
faroffthetrack's Avatar
faroffthetrack
yea there was a tsb on these tb gaskets
Old Mar 22, 2004 | 06:26 AM
ALSAIR's Avatar
ALSAIR
I put a brand new throttle bodie gasket (felpro) on saturday the 20th, did not fix it!!! I cleaned the bodie while it was off, spotless. I.A.C. works , idle is where it is suppose to be, but she run's like crap at idle!! If you bring up the throttle a little bit smooooooth! Motor mounts are fine, I have 4 diffrent books, I have tried everything! The answer is going to come from an old trick a mechanic knows!! Something simple and cheap, I hope. I am trying to sell it and I would like to fix it before I do.
Thanks
Al
Sorry I stole your post Meck1, but we are after the same thing!
Old Mar 22, 2004 | 07:36 AM
meck1's Avatar
meck1
No problem, Al, and I think you're right. Sounds like we've got the same problem. I put a vacuum gauge on mine, and it didn't show any sign of a cat blockage. Is there any other way to test this other than taking the cat off?
I will check the TB gasket this afternoon. I had already torqued the TB to make sure it was tight, but I didn't take it off to check the gasket.
My IAC valve is clean with good o-ring, gasket, etc. The Haynes Manual, though, says I should be getting 10.5 volts on the IAC solenoid when I'm actually reading full battery voltage. Does anyone know if this is or could be a problem.
Thanks for the suggestions so far. Keep making them, and I'll keep checking. Al is right. Somebody out there has the key to this gremlin.
Old Mar 22, 2004 | 11:33 AM
larry derouin's Avatar
larry derouin
I WAS gonna say something about AMC.....but some of you guys are too young to remember.........................
try spraying some WD-40 around the upper intake manifold gasket area. This gasket is like 3 mil thick. I've seen spray paint lay down a thicker coat.
Larry
Old Mar 22, 2004 | 11:47 AM
rhetor's Avatar
rhetor
Possibly a bad TPS.
Did you try a simple ignition tune up?
Old Mar 22, 2004 | 03:30 PM
ALSAIR's Avatar
ALSAIR
I did the WD-40 all around, also did the propane soldering torch. where you open the gas valve (DO NOT LIGHT IT) and with the long tip place it all along the intake manifold and you get the same results as you would with the WD, just get in alittle tighter! Meck1 check the back of your throttle plates, if you got build up on them, called coking, it will give you this problem. I put new plug's gapped correctly, cap and rotor, did the check for light show at night in engine compartment, but I will do that one again! Keep the suggestion's coming, I'll try anything!! You tell me to go outside and drop my pant's and fart 3 times to the west, I"LL DO IT, if it fixes my problem!!!
Al
Old Mar 24, 2004 | 10:43 AM
95BlackF150's Avatar
95BlackF150
My 95 misses at low idle right when it shifts 2nd 3rd and od once rms pick up some its ok only when rpms are slow have already done plugs wires cap rotor tp sensor and fuel filter also when i stop and put it in reverse engine wants to die
Old Mar 24, 2004 | 04:38 PM
Patrick_PDX's Avatar
Patrick_PDX
I could also possibly be a leaking EGR valve.
Old Mar 24, 2004 | 05:33 PM
ALSAIR's Avatar
ALSAIR
When you say leaking E.G.R. do you mean not closing all the way or a vaccum leak?
I noticed something today, you guy's tell me what ya think. I walked to the back of the truck and I could here popping. When I got down near the tail pipe the exhaust would make a popping sound. Sometimes constant and sometimes intermittent. I check under the hood the other night and no arching anywhere!
Al
Old Apr 2, 2004 | 12:57 PM
bebad96's Avatar
bebad96
It sounds like our trucks have the same problem, Al, my exhaust sounds the same way, and it's got a nasty studder to it through all the gears. My concern is that I just replaced the head gasket this past weekend and I hope that nothing's wrong internally i.e. the head.... I'm going to check for a air leak tonight...so any other suggestions on how to fix this problem would be welcome.
Speed-demon
3.8 & 4.2L V6
Apr 17, 2014 09:01 AM
MrRogers
Sep 2, 2012 02:12 AM
Mike8623
Aug 2, 2011 12:52 PM
460
Aerostar
30
Apr 28, 2011 06:19 AM
V10IRON512
New Member Introductions
Jun 9, 2006 11:12 PM
