steering coupling...(rag joint)
Old Mar 19, 2004 | 09:53 PM
raydioed's Avatar
raydioed
I,m wondering if theres a way to eliminate/modify the steering coupling on my 76 F100 as the holes in it are worn so much that replacing the "rag" is useless.What would be the best way to fix this?
Old Mar 19, 2004 | 10:21 PM
bob arrington's Avatar
bob arrington
when you replace the "rag" it woll include those parts also,bob
Old Mar 19, 2004 | 10:36 PM
raydioed's Avatar
raydioed
Thank you Bob but I was referring to the flange above the rag that looks to be pressed on the steering shaft,how can I get that off the shaft?
Old Mar 20, 2004 | 04:39 AM
Ford_Six's Avatar
Ford_Six
You will probably have more success on this in the proper forum.
Old Mar 20, 2004 | 11:33 AM
Mil1ion's Avatar
Mil1ion
Use an 12 point 11mm or 7/16" wrench or socket ,and loosen it so the flange slides off.
Both come off this way
Old Mar 20, 2004 | 12:53 PM
raydioed's Avatar
raydioed
OK thanks, the further I go the worse it gets.When I got the joint disconnected I found that there is lots of play (3/4") or more in the shaft goin into the steering gearbox,so do I have to replace the box or can I get parts and rebuild it ?
Old Mar 20, 2004 | 05:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Replace the box. You can get one from the suppliers in my sig or one of those listed in the links section of my FTE web page.
Old Mar 20, 2004 | 07:13 PM
raydioed's Avatar
raydioed
Ok thanks for the help guys,maybe now that I know what to do I can get my old six banger fixed and on the road again without wandering all over the place,as is its kinda hard to keep it between the ditches!Its in pretty good shape besides that and a cracked exhaust manifold which I will replace next.....Glad I found some folks that likes Ford trucks as much as I do and dont mind sharing your knowledge. Great group!
rhr1950
17
Apr 24, 2017 11:05 AM
shorerider16
18
Jul 22, 2016 06:48 PM
vidaliaman
May 13, 2016 11:43 AM
muleguitar
Mar 11, 2010 07:33 AM
66beater
Oct 4, 2004 09:54 PM
