Replacing the rag coupling
Old Jul 16, 2008 | 07:39 AM
rhr1950's Avatar
rhr1950
Does anyone know of an alternative to the rag coupling on the steering column. I had one of these come loose where it couples to the steering gear and was awfully lucky I didn't wreck!!! Is there a steering shaft assembly that elminates this coupling for a 1975 F100 at a reasonable price?
Old Jul 16, 2008 | 08:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/75 F100/350 2WD rag joint
Welcome to FTE
Is your truck 2WD or 4WD?
4WD's use a shaft & coupling assembly, 2WD's just use a coupler (rag joint).
The 2WD couplers are available from Ford, the 4WD shaft & coupling is obsolete.
D5TZ3A525A .. Steering Coupler (rag joint) / Fits: 1975/77 F100/350 2WD with P/S.
MSRP: $83.98 / FTEpartsguy.com price: $60.47
C9UZ3A525A .. Steering Coupler (rag joint) / Fits: 1975 F100/350 2WD without P/S / Also fits 1969/74 F100/350 2WD with or without P/S.
MSRP: $75.00 / FTEpartsguy.com price: $54.00
Old Jul 16, 2008 | 02:35 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Any ideas what to do when the 4WD's shaft & coupling assembly wears out? Other than find a decent used one?
Old Jul 16, 2008 | 04:35 PM
NOCO77's Avatar
NOCO77
I replaced mine with a Borgeson unit.
Old Jul 16, 2008 | 04:51 PM
F250army45d's Avatar
F250army45d
Borgeson is the best way to go I used one in my 78 F250 that I lifted but that truck is now gone. The shafts extend out for body lifts and can be cut down as well. I think LMC offers a similar shft.
Old Jul 17, 2008 | 03:48 AM
Dirt racer's Avatar
Dirt racer
I went with the Borgeson shaft also. Many places sell them. You just cut them to length. There are two u joints instead of the rag joints.
Old Jul 19, 2008 | 12:02 AM
mrjones111's Avatar
mrjones111
I was always under the impression that the rag joint was there as a safety device, to give in case of a front end accident, and keep the steering shaft from ventilating your chest. Not right?
Old Jul 19, 2008 | 03:18 AM
Dirt racer's Avatar
Dirt racer
The borgeson unit is a two piece. One slides into the other. My steering column is still a solid piece and would still probably kill me. Hopefully it would be quick. Ha
Old Jul 19, 2008 | 08:48 AM
78workhorse's Avatar
78workhorse
I think Ive seen on here the rag joint was to eliminate the vibration from the road. This reminds me I gotta check my steering today too.
Old Jul 19, 2008 | 09:07 AM
GLR's Avatar
GLR
Most NAPA stores have them in stock as a "universal" picked one up yesterday for a 67 Galaxie.
Old Mar 3, 2017 | 08:01 PM
eric8's Avatar
eric8
So what part number would a 1976 2wd F100 WITHOUT power steering use?
Welcome to FTE
Old Mar 4, 2017 | 11:46 AM
NumberDummy
D6TZ-3A525-B .. Steering Coupler (rag joint) - Use with Manual Steering / Obsolete ~ 5 available NOS
1976/77 F100/150 4WD / 1976/77 F100/250 2WD & F350.
Old Mar 4, 2017 | 12:35 PM
eric8's Avatar
eric8
As always, thank you SIR!
Old Mar 4, 2017 | 09:46 PM
eric8's Avatar
eric8
Where might one locate one of these 5 that are available Number Dummy?
Old Mar 7, 2017 | 06:18 PM
NumberDummy
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
HIGH BUCK! BOB ALLEN FORD in Overland Park KS has 1 = 913-381-2999.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959
