My Expy is M. Flake Burgandy. At certain angles and in certain sun light you can see all the swirl marks in the clear coat. They almost like like scratches. Don't notice it on the red truck.
Help! Does anyone have any recommendations on how to get these out? Zaino? Zymol?
________________________
You can never have too many FORD's!!!
2000 Eddie B Expedition
2001 F150 SuperCrew
1999 Mountaineer
I've always had good luck with Meguiars (sp?) products. They are available almost everywhere. You'll want to get the professional polish to get rid of the swirl marks.
Yea, I can get that local, and it's fairly inexpensive. I thought for sure I was going to need something that was going to be $20 a bottle. Thanks I'll give it a try.
2001 F150 SuperCrew
1999 Mountaineer
Hi dannys 58
If you want to put full days work in to it this is what you can do like the pro's. Wash truck clean as U can get some 2000 grit wet/dry sand paper, Xtra fine buffing compound and good wax.This will make your rig the best that it can be.Good luck to you.
I use Zaino products on my Benz and it is definitely good stuff. A little on the expensive side but it definitely gets the job done. Here is a great article one of the guys on a Mercedes board put together. It is no amateur job but if you really want your clear coat to look like glass you should read up on this.
Wow, Samoan thanks a lot that was great little lesson. You Benz boys are serious about the finish on your cars. I actually learned alot, and I like the clay idea. I just don't know if I could ever be as serious about washing my rig, as they were at this thread:
