how do i clean my mag wheels
It also depends on if you have Mags (magneseum) wheels or Aluminum with clear coat on them.
If true "mags" take sand paper, say start with a 800 or 1000 grit to get the crud a scartches out then goto a 1500 or 2000 wet sand then to a rubbing compound, then go to a good aluyminum polish to get the swirls out.
If you have aluminum with a clear coat thats gotten cloudy and cracked, there is two options, one is to have the wheels recut by a machine shop to remove the clear, or if the wheels are not that expensive, buying new wheels.
bigdaddylove
06-29-2012 10:24 AM
thesprocket26
07-13-2004 01:38 AM
