Offroad & 4x4
Extended Brake Hoses
Old Mar 19, 2004 | 09:17 PM
proeliator's Avatar
proeliator
Glad you found some. I had mine custom made at a local hydraulic hose speciality shop too. The best will have a braided outer to keep swelling at a minimum.
Old Mar 20, 2004 | 05:44 AM
shortroundctrh3's Avatar
shortroundctrh3
I wasnt able to get the braided stuff from him. But the hoses he did give me have thicker walls than the stock stuff. I watched him test the line up to 4,000 PSI before he was happy with it. And it was ALOT cheaper than I thought it would be. Only ran me $49.31. The funniest part about this whole thing, is where I found the guy/company to do this. Name of the place is: Industrial Power Supply Co. Go figure that the guys who put up our local power lines/transformers can do custom brakelines.
Will.
Old Mar 21, 2004 | 12:22 AM
fishmanndotcom's Avatar
fishmanndotcom
are you sure you even need it? every lift i have put on didn't require longer brake lines! even the 6" lifts.
-jason-
Old Mar 21, 2004 | 01:10 AM
shortroundctrh3
Yup, I'm sure. I put the truck up on stands to check the travel, it would have popped the stock hose. Stock was only 8 inches long. I went to 12 inches and that gives me about 1 inch worth of play at max travel.
iilijah
1997 - 2003 F150
19
Feb 15, 2011 07:44 PM
Nimby
Dec 13, 2010 12:50 AM
$Simpleman76
Aug 12, 2007 08:02 PM
kuhlero
1997 - 2003 F150
Feb 23, 2007 12:50 PM
78250crewcab4x4
Offroad & 4x4
Jul 2, 2006 01:35 PM
