extended brake lines
Old Aug 8, 2007 | 08:24 PM
$Simpleman76's Avatar
$Simpleman76
is anyone running the stock front brake hose with a 4in suspension lift, i ordered the extended brake lines but they are not going to bolt up like the original ones and I was wondering if I could run the original length hose are do I really need the extended
Old Aug 8, 2007 | 09:29 PM
fulltimehiboy's Avatar
fulltimehiboy
what brand suspension lift did you use? what brand brake lines?
Old Aug 8, 2007 | 09:47 PM
77460f150's Avatar
77460f150
I am using the stock front brake hose on both of my 77's, one has a 3" lift and the other has a 4" lift, no issues so far. There seems to be quite a bit of "sag" in that hose. I am going to replace the one on my black truck soon, due to age. -Ed
RNOVRIT's Avatar
RNOVRIT
See how much slack is left in your brake line at full suspension droop. If your brake line is too short and your axle goes all the way down, it will rip off your brake line. That is very bad!
Old Aug 8, 2007 | 11:32 PM
75F350's Avatar
75F350
What kind of truck?
I have run stock lines on F-250's with very large lifts by simply moving the hard line under the frame instead of through it. All you have to do is remove the bracket, and rotate it upside down, disconnect the rubber line and then reconnect everything under the frame, and bolt it all back up again. Even the clips will go back again. If you are running front springs that are limited on flex, this will be good for over 6 inches.
If you are running some high flex springs like the Super Duty front spring,, or custom springs that provide more than 8 inches of lift, then you will need to run the lines under the frame and buy an over the counter line like the "Skyjacker" part #FBL93 SS brake lines. This kit comes with everything.
Old Aug 9, 2007 | 02:40 PM
kaotikedge_111100's Avatar
kaotikedge_111100
2wd brake lines are quite a bit longer and mount up the same. That's what I bought and it worked out perfect.
Old Aug 9, 2007 | 07:48 PM
$Simpleman76
I have the skyjacker 4" lift kit, I think I will get a stock hose and look at it, I know when I took all the stuff off the frame the front hose was very tight even with a stock ride height, so someone must have installed the wrong hose, I hope I can make it work because if I use the aftermarket extended hose I will have to butcher my right side hard line to make it line up with the hole in the axle housing if you know what I mean
thanks
Old Aug 12, 2007 | 08:02 PM
$Simpleman76
I called inline tube and they have the setup I need to use the extended brake hose
thanks for the help
Iopoh
Dec 27, 2014 06:29 PM
rb2
Jul 30, 2014 08:02 AM
rat49f6
26
Jul 21, 2014 04:26 AM
Crocodile000
16
Jul 21, 2013 05:32 PM
rpenterics
Sep 30, 2011 11:06 AM
