Offroad & 4x4
brake fluid spewage
Old Jul 1, 2006 | 12:39 PM
78250crewcab4x4's Avatar
78250crewcab4x4
brake fluid spewage
so my front right brake hose (flexible hose) exploded the other day and i have some questians
I want to lift this truck 6 in. eventually, should I buy good extended stainless hoses now?
if so what brand do you recomend?
I have a d44 now but if I swap a d60 from same vintage (78-79) will the brake lines from the d44 calipers fit on the d60 calipers?
but wait, there's more, the bleeder bolt broke off inside one of my calipers, is there any way to get this out?
so I just rebuilt my rear brakes and I go out to test them when the front line spews, I really do love old trucks
Old Jul 1, 2006 | 01:30 PM
rebocardo's Avatar
rebocardo
Either that or make your own extended lines from the NAPA hydraulic catalog like I did.
Yes, just do a search. I and others have posted about the various techniques to do it. Though if it has broken off below the surface, the only way is to carefully hollow out the bleeder and try to pry the remaining "skin" out with a needle nose.
Old Jul 2, 2006 | 06:59 AM
Jmudder79's Avatar
Jmudder79
If you have a Dana 44hd with the dual piston calipers then the the calipers themselves will work with a 60 also. Just did that myself a month or so ago.
Old Jul 2, 2006 | 01:35 PM
chrono4's Avatar
chrono4
go longer now, and yes they should boltup to the 60
Bastin
May 20, 2017 01:44 PM
CollinsCD
Mar 31, 2017 01:05 PM
400v8f250
15
Oct 14, 2015 04:20 PM
simulatedjim
Aug 9, 2014 07:51 PM
Neil64
Apr 6, 2010 10:19 AM
