Crate Engines
Old Mar 18, 2004 | 12:16 PM
Trek93023's Avatar
Trek93023
Crate Engines
I have a 5.4L engine in a 98 4wd f150.
What is the best crate engine to buy...I dont know anything about this...if I could get some info that would be awesome. Is there a limit to the HP my truck can physically handle (within reason)? Also what would that do to my gas mileage?
Thanks for the help!
Old Mar 18, 2004 | 01:43 PM
Mike G's Avatar
Mike G
Just curious, what's wrong with your current motor? I will venture to say that if you funds aren't an issue, you can probably drop what motor you want in it. What are your plans for the truck? Keep in mind that changing engine families will cause a need for frame mounts and tranny changes (maybe). You can surely count on your mileage going down, if you get bigger displacement, it's harder to keep your foot out of it
--Mike
Old Mar 18, 2004 | 02:48 PM
Capone's Avatar
Capone
If compression is fine and the truck runs well...I wuld consider installing a Powerdyne supercharger.....$1999 at summit racing
boost/power when you need it...mileage when you don't
Old Mar 18, 2004 | 09:49 PM
Trek93023's Avatar
Trek93023
My engine is in tip top shape, I am just trying to learn a few things..I am definitly not considering it. I was just curious as to what it involved...it may be possible in the future if I wanted to totally redo a truck.
About the supercharger...what is the diff in that and a turbocharger? Do I have to get a new hood for that addition.
Thanks Guys, for the help!
Old Mar 18, 2004 | 10:48 PM
MustangGT221's Avatar
MustangGT221
Ford offers crate motors...even a complete lightning motor w/ supercharger....fordracing.com/performanceparts.
Old Mar 19, 2004 | 02:59 AM
3eggOmelet's Avatar
3eggOmelet
Turbochargers use exhaust gases to run a compressor to force more air into your engine. Superchargers use your engine's power (a belt from your crankshaft to the compressor) to do the same thing. The difference is mostly about *when* they apply the extra boost to the intake.
In your case a engine swap probably isn't really what you need, but you could learn plenty about possible engines and what mods they require .
Here are a few google searches that will return good info:
Ford 302 small block
Ford 351 Windsor small block
Ford FE big block
Ford 460 big block
Also look into the 351C, 351M, and 429.
Old Mar 19, 2004 | 11:58 AM
Trek93023's Avatar
Trek93023
The searches you gave me are great, but I have a 5.4L
Will those still help me?
Thanks for the great info!!
Old Mar 19, 2004 | 01:44 PM
78fordman's Avatar
78fordman
check the 5.4 modular forum down below.
Old Mar 20, 2004 | 06:13 AM
Jasperford97f150's Avatar
Jasperford97f150
I'd say if your motor is running fine, leave it be. But if you ever do put a crate engine in it, I suggest using a Jasper engine. They r remanufactured ford blocks, but the vital parts such as cranks, cams bearings, lifters and the like r made within tighter tolerences. Jasper also takes it upon themselves to work out any bugs in the motor that Ford forgot about. If you order a Jasper they also have a great warranty. You can also order performnace, or even custom models. They directly replace your factory motor, no modifications required.
Old Mar 20, 2004 | 06:16 AM
Jasperford97f150
Oh yeah...I almost forgot the most important part...price!
They're reasonable. I paid $2,900 for my 4.6 L romeo. You would probobly look at $3,800 for a performace 5.4 L (that's including shipping)
Old Mar 20, 2004 | 04:22 PM
Trek93023's Avatar
Trek93023
thanks guys!!
Old Mar 21, 2004 | 09:57 AM
78fordman's Avatar
78fordman
marshal makes a good engine also.
panic
Apr 28, 2017 12:40 PM
Kieran Underhill
Apr 28, 2016 03:04 PM
brcowan
Modular V10 (6.8l)
19
Feb 3, 2016 10:02 PM
Oxfordrider
Sep 21, 2015 06:42 PM
GeneStoner
24
Dec 27, 2002 05:49 PM
