Sponsored by: Real Truck
Need help on wheels
Old Mar 17, 2004 | 05:56 PM
mcope's Avatar
mcope
Angry Need help on wheels
Brought my 2001 F250 XL Superduty Ext Cab home last night. I'm slowly going through everything and I just noticed that the spare tire is mounted on an eight lug rim while the rims on the truck are actually seven lugs. Obviously this is not going to work. On the truck are the stock base Ford steel wheels with the plastic wheel cover but they are 7 lug. Called the place I bought it from and they indicated that they had never seen a 2001 F250 with seven lug rims and all the 2001 250's on their lot were eight lug. When I first looked at the truck, it had no spare and they put one on it before I picked it up. Obviously they didn't check to see if it would in fact work. They also said they did not have a seven lug spare to swap it out with. I'm a little po'ed and confused. I did a little research and I've seen it said that only the 98 F250's came with seven lug rims. Where can I get the right rim for my spare? Why do I have 7 lug rims on my 2001 F250? I can't be the only one,can I?
Old Mar 17, 2004 | 06:23 PM
Bordaine's Avatar
Bordaine
Hub cap has 7 lugs
rims have 8 lugs
Steve
Old Mar 17, 2004 | 08:12 PM
Badford's Avatar
Badford
first off what f250 do you have? a superduty, an f150 style 250 or the older 97's style 250.
i think all 3 were out in 98.
Old Mar 17, 2004 | 09:15 PM
Yeti's Avatar
Yeti
Originally posted by Bordaine
Hub cap has 7 lugs
rims have 8 lugs
Steve
This about wraps it up.. pop the center off, I bet there are 8 lugs under there...
Old Mar 17, 2004 | 11:45 PM
mcope's Avatar
mcope
Badford, it's a 2001 F250 XL Superduty Ext Cab, V10, Long Bed, 5-Speed, 3.73. I think Bordaine pretty much nailed it. It has the plastic hubcaps where the lug nuts actually hold the hubcap on so there is no center cap to pop off and there are definitely only seven lugs - I can see them all. I will eventually replace everything with some nice wheels and maybe some REVO's, but right now I need a spare thats going to work when I need it.
Old Mar 17, 2004 | 11:56 PM
Ev2Demon's Avatar
Ev2Demon
I can only assume these are the hub caps you have?
If so, the lug nuts you see on the caps are only for decoration, and do nothing to hold the hub cap to the wheel. If you take the time to pop one of the caps off, you will see there are actually 8 lug nuts under there.
Old Mar 18, 2004 | 06:17 AM
Yeti's Avatar
Yeti
mcope, if you in fact have 7 lugs, you may want no want to drive it, and save it as a "1 of" because I have never ever seen nor heard of a Super Duty from 99 up having 7 lugs.
Old Mar 18, 2004 | 07:20 AM
mcope's Avatar
mcope
EV2DEMON you are correct. I popped one off this morning and sure enough there are eight lugs underneath. I can't believe how real the lugs on the hubcap look. Yeah, I feel like an idiot now for sure, but at least I dont have to worry about having the right spare. Been an F150 guy since way back, but this is my first F250 so I have a lot to learn. I am really enjoying that V10 though. Thanks for all the help.
cwatkin
1997 - 2003 F150
15
Oct 31, 2021 10:24 AM
john jamieson
Jul 17, 2016 08:16 AM
bignewf
Apr 21, 2016 05:24 PM
bignewf
Apr 21, 2016 12:31 PM
BeerHunter125
1997 - 2003 F150
Aug 21, 2015 09:41 PM
