1978 - 1996 Big Bronco
Bronco Exhaust Question
Old Mar 16, 2004 | 10:08 PM
tigerhawk_212's Avatar
tigerhawk_212
the y-pipe is the pipes that come down from the manifolds and form a "y" and connect to the cats or whatever you have
Old Mar 16, 2004 | 10:09 PM
WhëëlMå1's Avatar
WhëëlMå1
The Y pipe encompasses everything from where the stock manifolds end to where the muffler mates with that pipe. Does youre catback mount to that pipe with a flange, or is it a slip fit?
Rich
Old Mar 16, 2004 | 10:15 PM
LEIGUY's Avatar
LEIGUY
it is welded to a pipe welded to a cat....why do i need to worry about a y pipe... im not getting that far up there, just the muffler and back
Old Mar 16, 2004 | 10:17 PM
LEIGUY's Avatar
LEIGUY
so would the new pipe slip into the one connected to the old pipe at the cat and i would use and exhaust clamp to get it on good?
Old Mar 16, 2004 | 10:18 PM
WhëëlMå1's Avatar
WhëëlMå1
You dont have to. It was merely pointed out that you would have to use a hacksaw or something similar to remove youre stock muffler. You would then use exhaust clamps to clamp it in place (one end being connected to the Y pipe).
Rich
Old Mar 16, 2004 | 10:33 PM
LEIGUY's Avatar
LEIGUY
so would the ne wpipe fit in the old one
Old Mar 16, 2004 | 10:34 PM
LEIGUY's Avatar
LEIGUY
so it can be clamped
Old Mar 17, 2004 | 07:57 AM
WhëëlMå1's Avatar
WhëëlMå1
That all depends on which muffler you choose. They make them in many different pipe widths. Even if they did not offer one that fit youre stock pipe exactly, you could have a small adapter made at any exhaust shop or gas station for a few dollars.
Rich
Old Mar 17, 2004 | 02:12 PM
Gooch's Avatar
Gooch
You guys go about it the wrong way. Straight pipes off the headers sound the best. Yes my state has emission testing but it's every two years, so the amount of time it takes to put the coverter back on is worth it to me to have it run and sound good inbetween tests.
Old Mar 17, 2004 | 03:59 PM
jfrbronco's Avatar
jfrbronco
pace setter makes a good sounding cat back set up for 179.99,has all the hardware you need to install it.cheap price too!!
Old Mar 17, 2004 | 04:22 PM
LEIGUY's Avatar
LEIGUY
what is the biggest deepest flowmaster series.....i have seen 30, 40 50 90 70 and 80 series
Old Mar 17, 2004 | 04:31 PM
WhëëlMå1's Avatar
WhëëlMå1
http://www.flowmastermufflers.com/cgi-bin/flowmaster/mufflers.html?id=DEgLIihv
There are details for each muffler. I thought the 70 series I ran on my old 76 F250 (no cats, headers, dual 3" pipes) was pretty deep. I would buy them again.
Rich
Excursion123
Nov 29, 2013 09:07 PM
gizmoF150
2004 - 2008 F150
Mar 13, 2011 06:13 PM
bulldog150
Jan 14, 2004 08:07 PM
cheapfeel
Exhaust Systems
Apr 24, 2003 11:08 PM
cigarxtc
Exhaust Systems
13
Feb 22, 2002 10:35 PM
