Sponsored by: Real Truck
fuel injection problem
Old Mar 16, 2004 | 04:02 PM
jstrider's Avatar
jstrider
Angry fuel injection problem
1999 F-250 Superduty 4x4. Problem: started out running fine , after 10 - 15 minutes when I hit passing gear on interstate would only go up to 3K RPM and sounded like it was missing. As I eased off pedal would get to -point wher all of a sudden it would jump up to 4k or 5K but never had enough power to pick up speed. By the time I had gone 30 miles was constantly losing speed and had to get off I95. Took it to dealer, changed out two injectors, flushed entire system. 2-300 miles doing it again. cleaned out tank and cleaned injectors again. Same result
Old Mar 16, 2004 | 04:18 PM
99f350sd's Avatar
99f350sd
Sure sounds like a fuel delivery problem...Why all the cleaning? any dirt? what kind? Symptoms point to clogged fuel filter or bad pump..Low flow causing problem at high flow demand..
Old Mar 16, 2004 | 08:16 PM
FortyFords's Avatar
FortyFords
sounds like fuel delivery (pump in tank ) or fuel pressure reg. as 99 stated
They changed the filter also ?
any water in the tank ?
did they do a scan looking for fuel trims and 02 readings for lean conditions
also have the plugs ever been changed?
Rich
Old Apr 2, 2004 | 08:22 PM
jstrider's Avatar
jstrider
The dealer had a code for the injectors cleaned them,replaced two.Flushed whole injector system. Second time around I had the tank pulled and cleaned. Guy said that there was something in there that had consistency of undercoating. Recleaned injectors. How do you clear the codes? Do they clear automaticlly if problem goes away? Is the dealership the only place to get the codes checked and do a diagnostic?
John
Old Apr 2, 2004 | 10:17 PM
99f350sd's Avatar
99f350sd
I'm wondering why we have fuel filters. They don't seem to catch much do they..
Disconnect battery turn on lights for a couple of mins to clear codes..
robj1999
Modular V10 (6.8l)
Dec 20, 2014 09:48 PM
SkySkiJason
59
Dec 30, 2009 08:14 AM
michigan66
1983 - 2012 Ranger & B-Series
Mar 3, 2007 08:51 AM
BlueOvalOgre
1997 - 2003 F150
19
Jun 28, 2005 02:02 PM
Andywk
19
Jul 4, 2003 09:34 AM
