ICP duty cycle 67%, ICP 70psi - no wonder it won't start
It was one of those days when everything was going great, right up until it wasn't great anymore. Truck (F350 in sig) ran fine for 1000mi long weekend trip towing rockcrawler, then 30 miles after hooking up 5ver to head off to work, it stalled when I pushed the clutch in, briefly restarted when I let clutch out again, then chugged to a stop 1/4 mile after the turn. 70psi of fuel pressure, fresh batts, good alternator, full of oil, etc. I had just pulled a grade and hit 3200psi HPO pressure (gauge in A pillar), 20psi of boost, etc - everything was normal. Would not restart, so AAA towed it home and I jumped in the Excursion and hated life living in a hotel for 3 weeks...
Now I'm home and playing with my Christmas present, the AE is awesome (thanks RiffRaff!!!).
So, with huge Denso super starter zinging the engine over on freshly charged batteries, I'm getting 67% ICP duty cycle and less than 70psi ICP. The 70psi instantly falls to 0psi when stopped cranking. I see the X easily hits 1700psi while cranking and slowly tapers back to 0psi.
What am I looking for?
BIG (internal) oil leak - injector o-ring, etc?
Failed HPOP? (it would suck if I HAD to buy an Adrenaline... )
The HPOP is a rebuilt from Int'l about 100k miles ago - cleaned and re-used IPR (a little over 300k on truck). The injectors are Swamps 175 singles w/about 70k miles on them.
What did Santa bring you?
Check your HPOP resi and make sure it has oil in it.
Just checked again - about 3/4" or so from the top/just below the threads. Thanks Clay.
Considering the freaking volume of HPO I have witnessed this truck GUSH out while still 'running fine', its hard for me to believe a single injector o-ring failure could cause such a catastrophic loss in oil pressure.
I don't really understand how the IPR works yet. I understand the electromagnet bit, but how does it control HPOP pressure? Can it be the culprit here?
Is this a typical failure mode of IPR and/or HPOP? My last HPOP gushed oil out of the big c-clip thing...
Props on the AE Merry Christmas!
Sounds good C, how do I block those lines for testing? I'm sure I don't have any ORB anything, especially plugs or caps... Didn't you say something about pulling VC's and looking for a gusher past an injector o-ring, etc? That almost seems easier. I've had new CAC boots to install on the engine side forever, this is a good excuse to do that and some proper cleaning in the valley - since its been over 100k since that was all squeeky clean! You remember what it looked like back then? I wuz so proud.
In the meantime, does the duty cycle mean IPR is functioning properly?
Also, I've spoken with a couple people who know alot about these HPOP's that say this is not an uncommon failure mode. The 'weak pump' seems to be less common and I'm not sure where 'leakers' make the list.
I'd love to spend the day isolating whether the pump is bad - but I'd rather spend the time installing Big Oil. I just don't wanna do that AND fix an oil leak (I'm running out of time already ). This would cut into the BTS budget AGAIN, and may just instigate a 38R upgrade - but with big oil, a 38R and some live tuning, this PMR truck would be FINISHED!!!! Then the focus can be on what we can do to a certain forged rod Excursion in the driveway that needs a BTS just to get started.... Yeah, I'm prolly spending the money I save burning VO faster than I save it, but who's counting?? (paid off the X already!!)
Thanks again y'all and MERRY CHRISTMAS!!!!!!!!!!!!!!!
on
Here is some good reading and will answer your questions regarding the IPR and HPOP. http://www.forddoctorsdts.com/public...3HPOPGuide.pdf According the the diagnosis steps, it could be a bad/sticking IPR or its O-rings. I'm having some strange ICP/IPR related issues myself.
Thanks Joe. I was planning to yank IPR today and inspect, but had too much fun playing with the kids to get a roundtoit...
I have another PSD in the driveway. May even steal parts from it too! If it'll get me to FL next week. The VO pump in the X is out for repair - if we take it on the trip, we actually have to pay for our fuel!!! I don't know how you guys do it!!
