hesitant acceleration
Old Mar 15, 2004 | 11:26 PM
passady's Avatar
passady
I've got a 1994 f150 with the I6, 114k miles. It idles fine, but when I step on the gas the slightest bit, the engine hesitates, if I leave my foot on the gas that little bit, the engine will actually die. But if I push the gas further it hesitates to start, then revs up just fine and seems to run fine when it's running fast. I think sometimes while I'm crusing down the road it acts like it hiccups a little. But in any gear just above an idle, the hesitant engine turns into a disaster and the truck bucks more than enough to be embarressing and really irritating. I relpace the fuel filter today, but that didn't help... any other suggestions? I'm at a loss.
Old Mar 16, 2004 | 10:32 AM
larry derouin's Avatar
larry derouin
Sounds like what I went thru with my 93. replaced darn near everything except the converter and the EGR valve before I got the correct thing fixed.
Check your codes and see if you get 53 and or 63. You get either or both then replace the Throttle Position Sensor.
It's the sensor to the right of the Throttle Valve body inline with the valve shaft.
Make sure you gt the right one. Pull the Number right off the old TPS and cross reference to the new one. Don't let the Moron behind the counter tell ya "AW SHUCKS...They all do the same thing, this one'll be awright". INSIST on the correct part.
Larry
Old Mar 16, 2004 | 11:19 AM
passady's Avatar
passady
When you say "check your codes" do you mean take it to a dealer and have them run the diagnostics on it? Forgive me, it's been a while since I've worked on this engine (last one was on an '84 probably 8 years ago)
Old Mar 16, 2004 | 12:35 PM
FordF150Fixer's Avatar
FordF150Fixer
Passady; I think you can pull the codes from a '94 without having to go to the dealer. Its not hard to do. Check out the following web site:
http://www.broncodata.com/tech/codes.htm
kadrocker
Dec 1, 2009 08:28 PM
4DADDY
1997 - 2003 F150
Sep 11, 2007 07:07 AM
RoushFan00
1983 - 2012 Ranger & B-Series
Mar 7, 2005 09:07 PM
cutterjohn
1997 - 2003 F150
Jan 25, 2004 11:15 AM
390man
Feb 23, 2003 08:17 PM
