hesitation---> sucks!
Old Nov 27, 2009 | 09:10 PM
kadrocker's Avatar
kadrocker
Ok, Ever since I put a different 390 in my truck I've had hesitation. It's been in since August.
Just say I'm at a stop and want to accelerate, it'll hesitate for a second and feel like it's gonna stall on me. But if I give it a little more gas it'll accerate just fine- it doesn't lunge forward hard or anything but you can def tell I'm giving it a bit more gas.
Today I noticed a new symptom while driving on my way to work:
Just say I'm cruising and want to accelerate, the truck will hesitate, drop in rpm's and then when I give it a little bit more gas it'll go where I left off and rmp's will climb. It feels like the engine wants to stall but doesn't. When I'm around 2000 rpm the hesitate occurs the most, anything above 2000 the truck is just fine as I'm speeding up by then.
40 mph seemed to be a confusing speed for me to go because I was around 2000 rpm and the engine would buck/bog/loss power, but if i gave it a bit more gas, it would accelerate just fine.
The harder I hit my gas pedal, the less the hesitation is.
My grandfather said I ought to rebuild my carb. I'm starting to think he's right!
HELP! Keeping my foot heavy on the gas pedal is starting to drain my wallet!
Whatcha think guys?!
Old Nov 27, 2009 | 09:24 PM
vtjvt's Avatar
vtjvt
I would check for any vaccum leaks, and rebuild the carb,
Old Nov 27, 2009 | 10:48 PM
montana_highboy's Avatar
montana_highboy
I agree, vacuum leaks and/or carb issues are likely suspects, is your vacuum advance working and connected to a ported source (above throttle blades) on the carb?
Old Nov 27, 2009 | 11:12 PM
Riderman's Avatar
Riderman
As others have stated, check your timing, vacuum leaks, vacuum advance...and the accelerator pump in the carb will cause this. There are 3 basic "sections" in a carb. Idle, main metering, and power. Power being the accelerator circuit.
Old Nov 28, 2009 | 02:27 AM
Tees77f150's Avatar
Tees77f150
I would check and make sure you don't have a vacuum leak. That will be your fastest, and cheapest way to go, rather then spending money on a carb rebuild that may not solve your problem.
However, a rebuild may not be far away!! But first things first!! Check for a leak, and let us know how you made out. If you still have the same problem, then its time to move on! I take it you know how to check for a leak?
Old Nov 28, 2009 | 08:11 AM
jeffreysw's Avatar
jeffreysw
Rebuild kits are not expensive.
Like previous posters have said, it sounds like an accelerator pump / vacuum leak issue. Go buy a rebuild kit for your carb. They aren't expensive. Find a nice clean tabletop somewhere. If you're nervous, get a digital camera for documentation purposes (I did this when I changed the head gasket on my wife's Quad Four, and the pictures came in handy when putting the thing back together). Take your time and rebuild your carberator. Cleanliness, cleanliness, cleanliness.
I rebuilt the carb on my F100 because the gaskets were shot and it was leaking fuel, but I was pleasantly surprised at how much better the thing ran.
Old Nov 28, 2009 | 10:51 AM
fmc400's Avatar
fmc400
MSEE
Sounds like a textbook accelerator pump or vacuum leak condition. The others nailed it.
Old Nov 28, 2009 | 11:11 AM
kadrocker's Avatar
kadrocker
Thanks guys. I'll take a look at the ol' girl tomorrow and see what I can find out. I'll report back when I find out what's going on.
Old Dec 1, 2009 | 08:08 PM
kadrocker's Avatar
kadrocker
Forgot to mention- my truck has backfired through the carb twice in the past week while trying to start.
I have to nurse the gas pedal for about 30 seconds then she'll idle on her own. I don't have any choke yet, I'm gonna get a manual one here soon.
Think it's still the accelerator pump?
Old Dec 1, 2009 | 08:21 PM
gstanfield's Avatar
gstanfield
Vacuum leak or accelerator pump and without driving it I'm not sure which to recommend so I guess check out both. Does it do it worse when cold or when hot? That will help in figuring this out.
Or you could just go ahead and check both of those and we can go from there.
George
Old Dec 1, 2009 | 08:26 PM
kadrocker's Avatar
kadrocker
I think I have a stuck thermostat- because my engine is staying cool here as of late. Most of the time my engine heats up fine- once every few days it runs cool (which sucks because then I don't get heat!) I gotta get a new thermostat asap!
The hesitation/bogging is worse when the engine is cold. I can tell that for sure.
Old Dec 1, 2009 | 08:28 PM
kadrocker's Avatar
kadrocker
Oh yeah- I do plan on checking for a vacuum leak, just haven't had a chance to really give it a good look just yet. But once I do, I'll come back and letcha all know what I found out.
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Mar 27, 2012 09:12 PM
RoushFan00
Mar 7, 2005 09:07 PM
passady
Mar 16, 2004 12:35 PM
sigtauenus
Mar 12, 2004 06:30 AM
eric in tn
Sep 25, 2003 12:08 PM
