I am getting a check engine light on my truck after I installed my Quad box. I sent the box back and they send me another and I am getting the same thing, the check engine light after several starts. I am trying to loacte a scanner for this engine, but I am not having much luck.
I have gone to sears, pepboys, autozone,... looking for a lower model code scanner and code erasing but none of them work for the 6.0L! After some research it appears that our engines use a "CAN Protocal" which these scanners won't work on.
Well... the predator programmer has a code reader built in....
maybe someone arund u has one.... or you might want to get one since it seems to shift perfectly...
Your Ford dealer service rep. should be able to show where you can buy one that works 6.0,mine did. One of their mechanic downloaded a program into his personel PDA for the 6.0
Originally posted by jdadamsjr Well... the predator programmer has a code reader built in....
I might end up going to the predator if I can't get this worked out. I got the Quad back with their shift fix and I am happy, it shifts much better. I love the thing. It will be running the 1/4 in April and I have no fear of the shifting...
My only complaint is how anyone can claim on better fuel milage- I can't imagine not keeping the pedal down!
I'm near fort worth if I can be of assistance...
Got my turbo back exhaust from Quad...
Since I've not dynoed the predator, I don't know if the +100Hp is really +100... but Ken with Motorhaven says he's dynoed Diablo's other stuff and their ratings are usually conservative...
