fuel line disconnect
Old Mar 14, 2004 | 06:42 PM
blue oval blues's Avatar
blue oval blues
Angry fuel line disconnect
i am trying to put a new motor in my f-150. i have a 351w and cant get the fuel lines apart. i rented a tool kit for fuel lines and still no luck. is there a backwoods secreat to getting these things off. any help will be greatly appreciated.
Old Mar 14, 2004 | 07:21 PM
1982fordf100's Avatar
1982fordf100
There are 2 different size lines I have seen on these trucks. A 5/16 and 3/8 line. Make sure you have the correct size for the line. Press the tool all the way into the coupling so that it will completely release the metal little teeth inside the coupling. As long as you have the tool pressed all the way into the coupling it will come apart with a good pull. Hope that helps. Fred
Old Mar 14, 2004 | 09:38 PM
n2o88's Avatar
n2o88
Yeah, they can be sticky even when you have the tool pressed in there....just push the right size tool all the way in, spin it around and tug real hard and it will come off. Try wiggling it a litte too when your pulling. Don't hurt yourself.
Old Mar 14, 2004 | 11:12 PM
toomany's Avatar
toomany
The best thing I have found to free up the connections is use some WD-40 on them. Once they are soaked good, spray air in the connection this always seems to free them up. Sometimes they snap right off and other times I have spend a half-hour fighting them.
Old Mar 14, 2004 | 11:23 PM
PKRWUD's Avatar
PKRWUD
I've found that pulling the two lines together as much as possible when sliding the tool into the coupling helps quite a bit.
gammatino
Sep 14, 2025 08:51 AM
boomshockpow
Apr 15, 2016 07:54 AM
Royson12
Nov 28, 2015 09:52 PM
samuelplake
2004 - 2008 F150
Oct 12, 2015 12:32 PM
true blue
General Diesel Discussion
Feb 28, 2015 12:24 PM
