Issue routing return fuel line
Old Apr 14, 2016 | 08:00 PM
boomshockpow's Avatar
boomshockpow
I did injectors the other day and decided to do the blue spring kit. My buddy took one wrench to the line instead of two.. and..bent the return line. So I got a new one on amazon for like 20 bucks. no big deal. I went ahead and got the regulator in, got the bent fuel line disconnected on both ends, awesome. But then this is where I got stuck. Getting the old fuel line out ( and the new one in ) is like fitting a square peg in a round hole. My buddy suggested (and did) cutting off the old line, just to be done with it. So great, the old line is out. But now I have a brand new line that just won't go in. There is just so much in the way. Is there a trick to doing this? Please let me know! Thanks!
Old Apr 15, 2016 | 06:41 AM
npccpartsman's Avatar
npccpartsman
Maybe you should just replace the section of line that's bent and join them together with a stainless compression fitting. Cut the new line in the same place you cut the old line and slide them in (unless a compression fitting wouldn't work at that point).
Other than that, it's just a lot of taking things off until you can put the new line in and reassemble. It is a lot of stuff to move, but nothing really difficult, I don't think.
Old Apr 15, 2016 | 07:54 AM
boomshockpow
Eyelet?
Compression fitting would not work there. There is an eyelet on the side of the block. Removing that would give me the clearance I need. Am I able to remove that? I have a bunch of allen key wrenches that fit in the hole.
jh225
May 11, 2010 02:53 PM
99SevenPoint3
Jun 25, 2009 07:33 PM
TheSojourner
Aug 10, 2008 03:24 PM
SuperSnake
North Carolina Chapter
Aug 18, 2006 03:34 PM
jberylecrider
Offroad & 4x4
Aug 19, 2002 10:22 PM
