Sponsored by: Kumho
Bleeding Brakes
Old Mar 14, 2004 | 12:57 PM
Godder's Avatar
Godder
Bleeding Brakes
HELP GUYS!!!!
I have replaced my front calipers and pads. I need to bleed the brakes. Hayes manual is hard for me to understand. It refers to a "bleed pin" on some models. I can not find one on my 1989 F150. It is up on stands now, and I really need to get it down. Please help if you can.
I have done my research and know HOW to bleed them, it just appears that fluid is NOT getting to the calipers. The mentioned "Bleed Pin" will prevent that from occuring, if I could only find it.
Thanks in advance for all of your help,
Jim Prince
Old Mar 14, 2004 | 01:29 PM
weldingfreak's Avatar
weldingfreak
T have heard the same thing. there is a clip that fits in the combo valve that will allow the brakes to be properly bleed
Old Mar 14, 2004 | 03:24 PM
Godder's Avatar
Godder
Thanks. Can anyone tell me exactly where this "pin" is? I need to roll tomorrow, but it is looking doubtful. Any and ALL help is appreciated.
Jim
Old Mar 14, 2004 | 04:04 PM
weldingfreak
If you are just bleeding the front brakes then I would not worry about the pin. It is for the combo valve so if you loose pressure in the rear brakes it will shut it off fluid flow. i.e bleeding rear brakes.
Old Mar 14, 2004 | 04:23 PM
Godder's Avatar
Godder
Thank You Very Much... Any ideas why I can not bleed brakes? I am really lost here.
Jim
Old Mar 14, 2004 | 04:29 PM
weldingfreak
You may need to pump the braked a little mor . you are filling the calipers w\ fluid. If you look under the truck you may find where all the brake lines come together. that is the combo valve. under the valve is a rubber plug that is where the pin goes. It my be covered with mud
Old Mar 14, 2004 | 04:33 PM
Godder's Avatar
Godder
Thanks Rick.... Going out to check now.
Old Mar 14, 2004 | 10:01 PM
Godder's Avatar
Godder
Rick, or anyone who can help. I went and checked under my truck for the combo valve. I found the point where the lines come together as you mentioned. However, underneath it, I found what appears to be a metal, recessed cap, or possibly an allen type bolt or screw. I don't think this is where the bleeder pin is, unless it is UNDER that bolt or screw.
I am sooooo lost. The good thing is that I got another ride to the airport in the morning. The bad thing is that when I return Thursday, I will be in the same situation.
I have pumped, and pumped and pumped. I have opened and closed and opened and closed the bleeder valve a hundred times. Nothing is working. There is little, if any fluid running into my capture bottle when I open the valve. There is NO difference in the resistance of the brake pedal. And now, the truck is at my house, and I am unable to drive it to a shop to get this figured out.
So PLEASE.... any ideas or help from anyone will be sincerley appreciated.
I hope I have a bunch of new things to try when I return on Thursday.
Again, Thanks for all of the help,
Jim Prince
Old Mar 14, 2004 | 11:09 PM
weldingfreak
It is under there, A small hole It is the middle of the nut.I am learning about it too. Some other threads I came across spoke of it. You put a pin in there to reset the valve and pump really slowly, That is what I read anyway. I am having the same trouble you are. I bought the truck to be a work trucj and found both spring are broken and the combo valve is stuck. The owner before me let the rear brakes leak for years and the valve is stuck closed
Old Mar 14, 2004 | 11:28 PM
FSC's Avatar
FSC
Actually, my post to weldingfreak was supposed to go here, please refer to my post there as it applies here, somethig like that, FSC
It's been a long day,
Old Mar 14, 2004 | 11:35 PM
weldingfreak
I is a small world
Old Apr 2, 2004 | 02:05 AM
Godder's Avatar
Godder
Ok... Great News. I HAVE BRAKES!!! I ended up replacing the master cylinder. bench bleeding it, and then bleeding all four corners. I learned alot. My only problem is that after I replaced the MC, my "Rear Anti-Lock Brake" indicator on my dash will NEVER go out. What do I need to do to get rid of this light? All brakes work fine. In fact, better than they have in years. So, thanks for all the help, and hit me one more time with an answer to this question.
Thanks,
Jim Prince
Old Apr 2, 2004 | 09:27 AM
rebocardo's Avatar
rebocardo
When you bleed the brakes, you should clean the screen on the RABS valve (have to remove the brake line going to it - can be tricky), and bleed the RABS after you do the two rear brakes. Try this, once done bleeding, if it does not go out, with the key off, remove the fuse, turn the vehicle on, and then off, reinsert fuse.
Old Apr 2, 2004 | 10:55 AM
Godder's Avatar
Godder
Thanks Rebocardo! I will do and let you know.
Jim
Robert Blumberg
Aug 14, 2016 09:52 AM
hurst1979olds
Apr 20, 2016 11:11 AM
jonmammenga
19
Aug 17, 2015 05:05 PM
FLN
Jun 19, 2008 12:44 PM
tack338
21
Jul 17, 2003 08:37 PM
