spark plug problem
Old May 16, 2004 | 10:25 PM
fordman428's Avatar
fordman428
Originally Posted by eriksf250
since i have a 352, and i know there's a lot of guys in here with 352s, i would like to know what kind of spark plugs they run and what their part number is so i can check them out.
run autolites, i dont have the part number handy, but any parts place should have them, i havnt heard of a better plug yet for are FE's
Old May 16, 2004 | 11:54 PM
BB's Avatar
BB
Autolite #45
Old May 17, 2004 | 03:07 PM
eriksf250's Avatar
eriksf250
I checked out Auto Zone's website and they have Autolite (AP45) and (45). Which one do you have BB?
Old May 17, 2004 | 07:06 PM
BB's Avatar
BB
I run the plain 45's. The AP’s are platinum and the APP’s are double platinum.
For a low-compression motor platinum is ok but I wouldn’t run them in a hot performance engine, they’ll flake and most car manufacturers don’t recommend them anyway.
Old May 17, 2004 | 10:35 PM
FEmtnmax's Avatar
FEmtnmax
I run Autolite 45's in my 390. They work great.
I used to have a 340 Mopar that I ran at the dragstrip. That engine would miss with brand new Champion plugs, then run the rest of the day's races on an old set of autolite plugs and not miss a lick. Go figure.
Old May 19, 2004 | 03:52 PM
DanBailey's Avatar
DanBailey
I've been told those Champion plugs were junk.
Old May 19, 2004 | 05:00 PM
fordman428's Avatar
fordman428
i think champion plugs are made more for the tractor/mower, etc.. i havnt heard any goodluck running champion plugs in are older motors.
Old May 31, 2004 | 05:58 AM
campinrig's Avatar
campinrig
I had a wierd incident with my plugs. I bought Bosch Platinum plugs for my truck and my truck won't start with them. I checked to make sure they are right and I gapped them right and they won't work. The funny part is that the old ones will still work.
Platinum plugs are best suited for any DIS system, and this is due to the fact the PCM actually wil fire the plug backwords if you will. The C.O.P. setup isn't as noticeable, as the master coil pack often found on the 4.6/5.4, and even Fords V-6's where those will actually fire 2 plugs at the same time, one plug fires from elctrod to ground, and the other fires from ground to electrod. Because of this they need the planium tip for this to happen. From the factory they actually put a normal plug on one half and platium one on the other half, to cut cost down.
I'm guessing your problem was not enough spark, as the platiums are use to way more Kv to fire, than say points ignition.
I've always run with the rule...Autolights for Ford, Champions for Dodge, and AC delco for Chevy, leaving NGK's for the imports
Old May 31, 2004 | 09:31 PM
c96drumm's Avatar
c96drumm
My 96 Exploder came with plugs that had the platinum electrode on center for one side and on the ground electrode for the other side due to opposite polarity. The platinum is very wear resistant, that's why it's used, not because it's required for the opposite polarity or more voltage. They just hold up better. At least that's been my understanding...
Old May 31, 2004 | 10:15 PM
campinrig's Avatar
campinrig
Your also right, let me see if I can find my books from my Ford training and see if there is anything in there
andrew_musson
2004 - 2008 F150
Oct 10, 2014 11:22 AM
mswpj
2004 - 2008 F150
Sep 7, 2010 09:28 AM
frantic
May 19, 2009 04:45 PM
krking
1997 - 2003 F150
15
Jun 6, 2005 01:53 PM
snocamo
Modular V8 (4.6L, 5.4L)
Dec 10, 2004 07:38 AM
