Exhaust on both sides?
Old Mar 9, 2004 | 10:14 PM
QUEBEN's Avatar
QUEBEN
I mentioned in another post that I am planning to go dual exhaust on my 84 F250 4x4 LB/Reg Cab. I currently have a single 3" pipe with a flowmaster, (I think it is a 40) its been a year since I put it on. My question is this. Can I run a pipe out the drivers side? I know the gastanks and lines are there but I have seen some Fords with sidepipes. I don't have any special desire for sidepipes, it just seems it would be easier than going all the way around the other side of the truck. But I understand the Gas concern is probably the main reason, right?
Old Mar 16, 2004 | 02:13 PM
WhëëlMå1's Avatar
WhëëlMå1
You definately dont want to bring heat anywhere near youre gas tank. Are you open to running a SI/DO muffler? That would give you the duals you are looking for.
Rich
Old Mar 16, 2004 | 08:32 PM
dk5122's Avatar
dk5122
Stay away from the tanks on our old trucks. You can run true duals down the passenger side and turn the mufflers vertical plenty of room. I did this setup on mine. A custom exhaust shop would be your best bet.
Old Mar 17, 2004 | 10:20 PM
FARM69's Avatar
FARM69
In the end its not that much more pipe to run duals down the passenger side. Not only is the fuel tank in the way, but if you have a 4x4, the front driveshaft and transfer cass might be difficult to go around.
____________________
90' F150 xlt 4x4 302 4-speed w/ 4.10 rear
Headers/true duals 2.25" w/ 28" glasspacks coming out at 45's
Old Mar 17, 2004 | 11:15 PM
QUEBEN's Avatar
QUEBEN
Thanks.
Thanks for the answers, that is kind of what I was expecting to hear. One more question though. What is the difference in the length of the mufflers. With my 460 it should sound pretty good once it is dualed, but what will the muffler length give me?
Old Mar 18, 2004 | 02:04 PM
85351ho's Avatar
85351ho
usually a longer muffler means quiter and deeper, while a shorter muffler means louder and more raspy
Old Mar 20, 2004 | 04:57 PM
WhëëlMå1's Avatar
WhëëlMå1
I would definately run a large case muffler on that 460. It will give it a great low rumble!
Rich
danger_ranger79
Exhaust Systems
Jul 12, 2012 12:33 PM
Deadeye1445
May 6, 2011 08:31 PM
Knight70F250
Exhaust Systems
Sep 4, 2005 07:39 AM
drbonestou
1978 - 1996 Big Bronco
Oct 18, 2003 04:58 AM
flowman
1997 - 2003 F150
Apr 10, 2003 10:18 PM
